Results 1 to 9 of 9
Thread: 110//185S Chain Case question
    thedeatons is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Cali
    361
    I am reassembling my rear axle/carrier, and am unsure whether I can come back later to install the chain case. I will not have a sprocket on the sprocket hub/spide (whatever you call it). Can I come back later and remove the rear wheel, and slide the chain case on over the axle or do I need to wait. I do not want to put the axle and bearings in the carrier if I have to remove them later... Thanks, James
    Jan 2005
    RI
    2,530
    you should be ok...just need to take the hub and wheel off and you should be all set. You definately shouldnt have to remove any bearings again
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by DeePa
    Are you sure?
    I thought the inner case needs to go on before the axle goes in because the hole for the axle in the case is not big enough to fit over the sprocket hub.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Apr 2005
    Cali
    361
    That's was I was thinking by looking at the diagrams... I don't have a case on hand to check it out... Can anyone clear this up?
    Jan 2005
    RI
    2,530
    actually, i think youre right. The chain case is on the left side of the bike and the axle removes from the left side of thebike after you take off the brake drum/ect...
    Mine was pretty trashed so i jsut did away with it altogether...easier to maintain the chain, and no crud gets built up in there over time.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2005
    Cali
    361
    Yeah.. I understand... It's a full resto so I need it. By the way, if someone has a perfect one, I could use it....
    Apr 2005
    Cali
    361
    I have received a couple good replies about this topic, but was hoping someone could tell me for sure.... I believe the axle hole in the chain case is elongated, and I don't know if this would let you slip it over the hub or not.... PLEASE SOMEONE GIVE ME A FOR SURE ANSWER.... I want desperately to make this thing a roller soon.... Thanks, James
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by thedeatons
    From what I can remember it must be installed before the axle is installed. It don't fit over the hub.
    Howdy
    Nov 2002
    Kirkville, NY
    3,831
    Now that I am home I can say that for sure the chain gaurd has to go on first.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
