I am reassembling my rear axle/carrier, and am unsure whether I can come back later to install the chain case. I will not have a sprocket on the sprocket hub/spide (whatever you call it). Can I come back later and remove the rear wheel, and slide the chain case on over the axle or do I need to wait. I do not want to put the axle and bearings in the carrier if I have to remove them later... Thanks, James
