Thread: Jeep wagoneer question?
    Apr 2004
    International Falls Minnesota
    546
    Does anyone know the size and length of a 70-80 jeep wagoneer axle and houseing? Or know where i can find a specs for a wagoneer. It has a 360 V8 in it with a 904 automatic tranny and im thinking about swapping the motor and axles into my CJ5. Anybody have advice or tips?
    Apr 2004
    546
    No one has any ideas?
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    I JUST sold my 77 CJ-5. It had the AMC 360 mated to a 4 speed manual with a granny first gear. The tranny was taken from an old AMC Commanche pickup,. and the 360 from a Wagoneer. My 5 came stock with the 304, and the 360 used the same mounts. Kept the same T case and all. It bolted right in.
    That being said.......
    I really suggest NOT doing this swap. It was nice for turning 35 inch tires like nothing, but after I had it awhile, i would have really prefferred the 258 straight 6 with a 4 speed manual. That's what I had in my CJ7, running 33 inch tires, and it was GREAT both on and off road. A 360 in a CJ5 is too much, in my opinion, unless you wanna turn 40+ inch mud tires really fast and burn crazy gas.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    Apr 2004
    546
    Like i saids its just an idea i realy want to put a 304,302,or a 305 in it i think that would work way better than a 360. But how big of axles would you run? Im only going to run 31's on it so i dont need super heavy duty axles.
    Central FL USA
    1,174
    I kept the stock setup, which was the AMC 20 rear, but with one-pice axle conversion/ Front was stock Dana 30.
    31s? I would go with a 258 straight 6 and stock axles. Remember: AMC did that from the factory for a reason ........because it was a GREAT setup to begin with. There were times when I regretted having a V8. Weight, fuel mileage, ease of maintinence, etc.
    Good luck
    Sep 2003
    Elizabethtown PA
    1,581
    you will want the axles from a 75-79 wagoneer or cherokee. the drive shaft is on the passenger side like your cj5. they are only a couple incjes wider. get the rear one also it a dana44 and it'll match the 6 lug pattern. the 80 and up ones drivers side ones and they are wider yet like a full size chevy
    if you use just the front you'll have to steal the rotors and hub from a 79 bronco to keep your 5 lug.
    i go offroading with a club in PA also it's cheaper them atv's i have a 85 toyota 4runner and a 82 pickup with 35" lockers and 5.29 gears.
    check out pirate4x4.com they are a big offroading web site like this is for atc's
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
