Thread: 300r intake boot
    Nov 2005
    illinois
    300r intake boot
    I have a 300r kit that I am putting together and I was planning on using a 38mm flat slide card. I have stock 84r that the kit will eventually go on and I was wondering what to use for an intake boot. Will boiling the stock boot and stretching it work fine? Also what would you suggest for reeds?
    3leggeddog's Avatar
    Nov 2004
    check with boyseen to see if they make a rad valve for that bike.the rad valve will usally accept a 38mm carb no problem
    Newfoundland
    5,280
    should be able to boil and stretch the stock boot.
    Jun 2004
    potsdam ny
    1,227
    the reed cage bolt pattern on the a/c and l/c 250r's arent the same??? i thought they were....
    Newfoundland
    5,280
    They are, the liquid R reed cage and boot will fit.
    Jan 2005
    Great Bend
    704
    go to www.1dirracing.com they have an intake that take a 38mm carb and its a straight shot into the reed cage. you can even upgrade the whole intake system from the them, intake cage and reeds. I plan on using them when I get my a/c R back together and my 85 T3
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
