Results 1 to 12 of 12
Thread: 1985 200x problems starting
    Nov 2005
    NEAR LA
    6
    I got a 1985 200x that won't start
    What I have done so far
    1) New NGK DR8ES-L
    2) Change oil with honda grade...
    3) Fresh 87oct gas
    4) Recharged the K&N air filter also tryed separating the carb from the air box
    5) Pulling the plugout and cleaning it
    6) adjusting the idle screw
    PLEASE HELP
    Pa.'s Highest City
    8,058
    Did you check for spark?
    Upper Black Eddy , pa
    245
    does it have good compression? makes a big difference wether it will run at all
    1973 atc90k1
    cobra exhaust,1978 thumb throttle ,& pegs
    '80 honda 110
    '84 yamaha 200 x2
    '85 yamaha 225 dx 4sale
    '85 tecate 3 basketcase
    '85 honda 200x
    '02 blaster race quad getting full rebuild
    '88 suzuki quadzilla sold miss it
    '00 honda XR650R supermoto
    Nov 2005
    NEAR LA
    6
    how do I check the compression? I was thinking of buying a used carb online....
    Nov 2005
    NEAR LA
    6
    i noticed that the new plug was blackish and wet I tried cleaning it no luck...
    Pa.'s Highest City
    8,058
    pull the plug again and reconnect the plugwire. hold it against the frame and kick it over. look for a pretty bluish white spark. If it's orange its week and no good. so your coil inside your stator is bad. that's what happened to my x and I've seen it 100 times on these boards.
    Also your plug should be more of a brown cardboard color I believe you may be running too rich.
    Maybe if your a little more specific about what happened. Was it running aleady? Did it smoke bad? did you do any mods like a performance pipe? stuff like that.
    Sep 2005
    Massachusetts
    1,272
    The first thing I would do is buy a new spark plug.
    Richland WA
    808
    Ignition. Youll probably find no spark at kickover. My 250R had the same problem till I found a bad terminal on the CDI plug, I could kick till my leg was dead and it wouldnt start, now that Ive fixed the wiring, it starts on 1/2 kick on a good day.
    Plug cleaning tip - if the fouled 2 stroke plug will fit in a car engine itll clean it up for reuse. I put the old 2 stroke plugs in the wood stove, they come out as clean as new.
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    Mind had issues starting as well. I changed out the pilot jet from a 40 to a 42 and then played with the pilot screw. That seemed to help quite a bit.
    1985 200X
    Nov 2005
    NEAR LA
    6
    i bought the used carb online it came off a running bike and everything is just fine now. Starts with one kick and runs great! I have since and should of to begin with taken apart my old carb the float had a crack in it so it didn't float... that was the problem then i guess. My rear brake needs bleeding becuase its got fluid but nothing happens when I press down so I am checking that next.
    thanks for all your help
    I am now a three-wheeeler!
    Nov 2005
    NEAR LA
    6
    Alright now my rear brake works like it should but most of your braking power comes from the front end. The front brake reservor is all corroded and borke apart so I need a new one wheres a good place to get one?
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    You can get a front brake set up from any dirtbike or even a quad. Just be careful if you get a quad set up, you don't want that extra braking power sending you over the bars.
    1985 200X
