I bought a 1984 atc70 in complete but non running condition. There is no spark on this bike. I bought one of the clymer manuals and have been running through the checks but have run into problems. For one my wiring diagram does not match theirs (e.g. my switch has blue/green wires instead of black) or the one posted on this site.
I replaced the spark plug and I checked the coil using an ohm meter. My values are either way off or I am not measuring it right.
Is there a way to check the stator without removing it from the trike? Also my bike has an unused molex type plug coming up out of the stator with two wires, and one loose black wire. I assume the black wire is what goes to the coil. Are the other two wires used?
Any other things I should check?
