Results 16 to 30 of 31
Thread: when to adjust the valves on my 350x
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by TeamGeek6
    Best thing Ive found for old Hondas is to adjust the valves with engine running and hot. That made huge differences in the Honda 4-street bikes because the clearance hot and clearance cold are never the same, and the clearances often decrease when hot.
    How are you suggesting he gets the feeler guage under the rocker while the thing is running. dude would have to be magic lol. of course there smaller when hot. the valve heats up and exaspands in length, expsecially that exaust valve.
    Will
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Charles Town, WV
    1,316
    I just pulled three pages from the manual...Click here for download
    Cold = < 95 Degrees F
    Hope this helps Brandon. Any other sections you need pulled lemme know. Might be quicker and easier until Craig gets out there.
    NE Arkansas
    2,344
    I never set the valves on it. It always had a slight ticking, but so does my 400EX, I know on the 400EX it's normal to hear a little ticking up front. Hope you get it adjusted right.
    My Rags
    Dec 2003
    SE PA
    683
    When Geek says do it while running, he's not talking about using a feeler gauge, he's doing it "freehand". The object, when adjusting valve clearances, is to obtain as little clearance as possible, while ensuring that the valve will not be held open at all. The clearance specs set by the manufacturer are the numbers that the engineers came up with to meet these criteria. By leaving some looseness, there is room for thermal expansion and such.
    If you are unsure, it is better to be on the safe side and leave them looser rather than tighter. If a valve is set too tight and hangs open, even slightly, the motor will lose compression and the valve could "burn" (they heat up and the metal of the valve face actually burns away). This normally happens to the exhaust valve. Then it's time for a valve job.
    As far as when to adjust them, a good maintanance schedule is the best way. I do mine once a season. If you don't know when it's been done last, it's time to do it now. As the valve faces wear, the face seats further in the head, which moves the stem up toward the rocker arm, creating a tighter clearance. I have revived several Hondas that were low on compression and given up for dead, simply by loosening up the vavle clearances because it had never been done.
    Oh well, that's just my take on it. My hands are tired and I'm going to bed now....
    [FONT="Palatino Linotype"]~My Rides (to name a few) ~
    1986 ATC250R, 1985 ATC350X
    1985 ATC250R Missile (90% done)
    1983 ATC185S
    1999 TRX416EX
    2003 Honda CBR600RR
    1990 Yamaha Zuma
    1985 XR80 w/100 motor
    1967 Honda CB77, '65 CL77
    1962 Puch 250 SGS
    1984 XR350R (owned since I was a kid)
    1972 Suzuki T350 Rebel, '73 T500 Titan
    1964 BSA A65 (needs restored)
    1968 BMW R60/2 mint original bike
    1976 Kawasaki KH500 triple
    Anybody have parts to trade for the above models?
    3leggeddog's Avatar
    Nov 2004
    yeah i am gonna adjust them soon.even if they are pefect i gotta check em.i just don't want to throw the timming chain or something cause i didn't check things out.thanks for all the help.
    craig i hope your ready to work on the beast when you get here,and eat some pumpkin pie at dinner sat. night.time you meet the family,lol,!!!!!!!!!!!
    Belsano, PA
    1,387
    Saturday...here we go...
    Should I bring handcleaner? Heck, I can wrench on it a bit I guess. As for the PumpkinPie...gotta pass...hate pumpkin pie (I am sure if I liked it, YOURS would be great) LOL
    What family are we talkin bout? Do they also think I am a serial killer?
    Do me a favor...shoot me your addy again. I wanna Mapquest it. I plan on leaving between 10-12 Saturday morning. Should make it there in about 5 hours. No trailer so I can make better time. Is there anything you need me to bring along? I will have my camera & Camcorder so I hope somebody is there to use them as we race. I will be giving you a call sometime Friday evening to chat some. GET SOME OF THAT X POSTED UP!
    L8R
    3leggeddog's Avatar
    Nov 2004
    i don't have any way to post pics. without getting uncle d down here.
    well as for sat. i got thanksgiving with my dads side,very cool people,all layed back and easy going.but that should be done before you get here.i thought you were coming earlier.
    no hand cleaner needed on this bike,plus i got some anyway.is it hard to adjust the valves?i dunno that they need adjusted.you get here and we'll figure it out.
    no pumpkin pie?dude are you in the taliban?
    Marion, Ohio
    622
    Dont forget my cameras DR. Bump!
    I got nothing...
    Richland WA
    808
    Quote Originally Posted by grundlegrabber
    Exactly, except when I mention " while running," it is with a feeler gauge. There was a marked power increase in my 550 and 750 Honda 4's between "factory" procedure and setting them hot. Its not hard to do with a little practice if you dont mind a little oil splash. Well, OK, its a royal PITA, but worth it.
    The engine spends most of its time running while hot, not cold so why adjust them cold?
    Yes, specs are set by engineers for new vehicles, that all changes with age and its a matter of experimentation to find where they are in an old engine.
    This noise may not be valves if youre hearing it in the exhaust pipe, it may be afterburn, which is fuel burning when the exhaust valve opens. The thin wall, hollow exhaust pipe will ring when the fuel goes off. This isnt so noticeable in a car because the manifolds are thicker.
    The early horizontal 4 Goldwings were bad for this because of weak ignition. "Valves out of adjustment" is blamed when thats impossible, they use hydraulic lifters.
    Listen to the exhaust pipes with a pipe or stethescope, you may hear them ringing. If so, and it is afterburn, itll wipe out the exhaust valves pretty quickly.
    Richland WA
    808
    Quote Originally Posted by slothminx
    Will
    Hi Will, havent forgotton about you. No, its not hard to feel a moving valve, the gauge slips right in because of teh oil on the surfaces. Tryit and C.
    May 2005
    1,408
    Hey, i think will give it a try then, i would have thought that the rocker would be moving too fast for me to get the feelerguage in and then if i did it would take the feeler guage with it and in that small hole would bend the feeler! but i got some old feelers around and an engine with rockers so ill give it a try.
    Will
    Richland WA
    808
    The feeler usually has to be bent to get it in, at least Ive always had to. Form it into position with the engine off, then roughly adjust the cold clearance with engine off. Then practice setting the clearance while the engine is running cold. Once youve got that perfected (and after youve thrown every tool you own across the yard and cursed a blue streak) then try it hot. youll probably get both yourself and the engine soaked with oil and burn a finger or two, but the results really are worth the trouble, especially if they are set too tight to start with.
    This is how all the drag racers *used to do it* on high performace engines (or still do), thats why they sold (or may still sell) oil deflectors for the engine to keep oil from spraying all over the garage when setting the mechanical valve clearance.
    Last auto engine I built would squirt oil 3 feet through the air onto the garage wall when it ran without the valve cover! he he he heh
    The old auto engines used to have specs for both cold and hot settings.
    May 2002
    Southeastern Wisconsin
    3,658
    LMAO, ya but when you do this to a V8 the item you are turning in and out isn't moving at a high speed, it's stationary. This is great if it works for you but it's totally unnecessary on a trike.
    Nov 2004
    Waterloo IL
    2,701
    I don't agree with adjusting valves on a V8 like that either. Why not get each cylinder on top dead center and adjust the lifter preload like you are supposed to? I bulilt my Mustang with studded roller rockers with poly lock adjustments. You couldn't adjust the valves like that on this car if you wanted to. It's EFI and the intake is over the top of the valve covers. My Mustang buddies call adjusting valves with the engine running Chevy man style. lol.
    Oh if you're refering to solid lifters then get each cylinder on top dead center compression stroke and set them with a feeler gauge, really easy if you know anything about cylinder running mates, just get it's mate in over lap.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
  15. #30
    na
    5,702
    hey 3 legdog,if you can hear a tinggy rattle noise in the pipe, it sounds like the timing chain is worn.my 250x has the same problem.be sure to check your valves.but when you hold it at a steady throttle and it tings in the pipe,that sounds like a chain stretched.if that is the case,as long as the guides are good,just replace the chain.and be sure to check the tensioner on the cylinder jug.those go bad a lot.i would just replace that when you do the chain.usually the cause is because the motor was run low on oil at some point.the top of the chain is the last place to get oil when running and if it was run low,it is the first part that suffers damage. service honda has about the best prices i have found for those.70 for the chain and 70 for the tensioner.welcome to 4 strokes.they are expensive for engine parts
    Proudly NOT a member of
    "Team on the Teat"
