Results 16 to 30 of 36
Thread: tire slime
    Rancho Cucamonga, Ca
    228
    Quote Originally Posted by 88 Turbo Coupe
    "Slime" (like some people I know) is not a PERMANENT fix. It DOES NOT last indefinatly. Use it to get your arse back to your trailor then get a new tire. If you want to try to see how long it lasts, Ive heard about 3 months. About as reliable as a plug.
    According to slime packaging it will last for two years. I run slime on all of my trikes and my quad(sorry} with excellent results. It will seal any hole that is 1/8 inch in diameter or smaller. I have saved so many tires with slime that I have to disagree. I just recently repaired a trailer tire with it and drove 225 miles from the desert back home on that tire. That trailer tire wasn't a real slow leak either. It was dead flat in about 2 minutes after parking.It is still holding air with out leaking and that was in july. I'm sure stans is good too but slime is magic for me. At least out here in the desert. It WILL NOT seal cuts or slices and has trouble sealing more than 7 small holes. Hate to sound like a commercial but the paddles I got with my R's were all flat and plugged. I installed slime and they are fine. Just my experience but I love the green stuff.
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    228
    Sorry, Left out the answer to the original question. 12-16 ounces of slime per tire is fine. As far as high speed wobbles go I've never had any and I spend a lot of time pinned in 6th going from Randsburg back to cal city 32 miles or so and most of it pinned in 6th. My R's are stock but they're still pretty fast.
    own:
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Quote Originally Posted by el Pollo
    Ahh. An area of expertise for me...
    Slime is basically a consumer's version of OTR Sealer. And most of the time the reason it doesn't seal correctly is because some people don't apply it correctly. The best way I have done is to unbolt the wheel and tire assembly from the trike/quad/wheel barrow/whatever, and apply the Slime. Air up the tire to roughly 15 pounds and bounce the tire while spinning it for a few minutes. That way it will coat evenly and not cause a wobble once it's back on the machine.
    And yes, it is a temporary fix. The best fix if the injury is up to about 1/4" in diameter is to use the nylon string plugs. The innerliner in the "quad tires" are too thin to accept a patch. And "fix-a-flat" is utterly useless. It has the consistency of milk and does squat to seal a leak even temporaraly.
    When I used slime, I put a block under my trike to suspend the front wheel then put the slime in and aired the tire up to between 10-15 psi (higher then normal just til the slime was distributed) and rotated the wheel continuously. All that happened was the slime kept oozing out of the pinholes in the tire. Yes I used the slime for tubless tires. I thought maybe I had too much pressure in the tire so I kept lowering it until I got down to operating pressure...still no luck. I'll never use it again, ever, and I always deter others from using it. I've used Fix-a-flat a number of times with excellent success repeatedly. I seems to come out of the hole and quickly rubberize, and I've used it as a permanent solution with no problem, in fact one of the tires I used it on has been on my dirtbike for years now and I ride that harder then the trikes.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Jan 2005
    RI
    2,530
    the thing about fix a flat is that it hardens...so if you have an unsuspended trike, there goes half of you suspension
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    HOLD UP!!! "FIX A FLAT IS WACK" lol that stuff suckssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssssssssssssss sss.....i remember having a nail go thru my tire so then i put some fix a flat in did everything the directions said drove slowly around and ZzzZZZzzZZZz thats stuff was flying put that lil hole like a squirt gun!!! lines of white crap everywhere all up and down the street lol all over me that was the worst. slime is 100% way better then fix-a-nothing. I got a another nail is some newly bought tires and (damn nails) then put one small bottel of slim put the hole side facing the ground and boom done hole is sealed, did that 1 year ago havent put air in that tire since. (alot of times depends on hole size)
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Aug 2005
    Lancaster, PA
    316
    Well, after reading everyone's testimony on how well slime works, I'm guessing that I just had a bad experience with that stuff and I've become hesitant towards using it again, but anyway fix-a-flat did work for me.
    Trikes
    Bikes
    Oct 2005
    Pennsylvania
    863
    Ill bet mom said liver was good for you-But youll never try that again either!!!Do what works for you, (Or dont do what doesnt?????) There isnt , and never will be, "Miracle in a Bottle", But dont condemn something, or swear by something, Just because someone else does. Try it.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    mad_max is offline Just Too Addicted Arm chair racerJust too addicted
    Kansas
    462
    Timely topic.... I ride primarily in pasture w/ some timber. I just pulled a 1.5 inch long thorn out of my front tire. This particular tire did not have slime in it because this was the first leak I've had with it since I bought it. My rears both have slime in them and I've had zero problems with leaks on them since.
    I ended up putting a plug in the front and then dumping a bottle of slime in it as well. I've got no complaints. Note: If a "slimed" tire needs to be removed from the wheel it is rather messy.
    Oct 2005
    Pennsylvania
    863
    I work for Bridgestone Tires- You aint seen messy til you dismount a tire that has 3 gallons of fix a Flat in it -cuz the moron didnt know when to stop. Also- by virtue of experience---Fix A Flat is FLAMMABLE!!!!!!!
    Aug 2005
    Lancaster, PA
    316
    Quote Originally Posted by Unclediezel
    What I do know is that I definately love liver. Mmmmmmm.
    Trikes
    Bikes
    Jan 2004
    NJ
    1,646
    I guess all products have their place,and thats fine. But for me I cannot go to the mountains, abandoned railroad track, the woods, sand pits, vacation, or the atv track and have a tire with a hole in it and then to have a failure. When I beat on my ATC/ATV I want it to be as close as 110% as I can get it. Knowing I got some stuff to TEMPORARILY fill a HOLE does not sit well with me. When I'm screamin my ride (beatin the piss out of it) and have a tire failure--no way--due to some filler stuff? Do you think for a moment that professional riders ride with fill in their tires is safe? I'm not a pro but I do it right. For the casual/soft riders it must be OK, but for me NO WAY. I'll use it to get me home but thats about it. IMO
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Jan 2004
    NJ
    1,646
    Oh, I forgot to mention, plugs suck too.
    Laegers ATC500R
    228
    As far as profesional riders using it, I know 100% that mant profesional atv cross country and desert racers use slime in their tires to PREVENT flats. I was turned on to the stuff by a former pro desert racer named Fred Wing. I have seen Denny Wolf a fast quad racer install it befor the vegas to reno race. And Dan Smith former Husky racer and very very fast guy in the desert used it also. Try it, use it to prevent flats and you will see. I just have used it for way to long with excellent results and zero handling or tire problems. I ride fast, I ride hard, and I do not baby my trikes, nor have I had a flat due to a puncture in years.
    own:
    Sep 2005
    FL
    855
    I have all ways had good luck with slime or simlar products. I keep a couple around when I go riding. The only time I had a problem with it was when one of the knobs on the side of the tire cracked. I just used one of those stips to plug it up. No problems since. I would say it's worth the money.
  15. #30
    Sep 2005
    FL
    855
    I don't think he is talking about Fix A Flat. The slime is diffrent & not hard to clean out of tires. I have done it more than once. That would be a hell of a mess though 3 gal of Fix a Flat.
