Anyone using a hydraulic clutch on ther ride?
3 CR500R's and counting. Do I really need 4???
Do I really need 9 Tigers?
Laegers ATC500R
DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
I want to get one. I contacted Magura directly (the distributor) and they were clueless. They sais that if the ATC is the same as the TRX, then it should be OK, but before I spend $300 on a clutch cable I want to have conficence that it will be the right length and fit correctly. So, no but if someone has some input, I'd buy one.
I can confirm that the Magura hydraulic clutch kit for the TRX 250R does indeed fit the 85/86 ATC 250R. It is a nice piece, and the trickness factor is high, but honestly, I don't think that it works any better than a properly lubed cable.
You don't have to pay $300, by the way. I found mine, new in the box, on eBay for about $180.
Hope this helps.
Brian
What is the major consideration to find the right hyd. clutch to fit any bike? Would it be the cable, cable end, length? I would think the resovour and lever itself would be the same on all bikes.
Laegers ATC500R
I would think the major thing would be the motor mounting setup. Since the TRX and the ATC have the same motor, the only other consideration would be the length. And Rockymountainatv has 'em for $200.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
