just run 32:1. it works, i never foul plugs and all 2 strokes smoke, but as said above, you need to clean your carb....and you dont check the transmission oil, if you dont know how old it is, just change it, if it is nasty looking i would change it and go for a short ride and change it again to get all the crap out, after that, just change it every couple rides or so....use 10w30, try not to use full synthetic because it can make your clutches slip more and you will burn your clutch up quicker. you can use synthetic blend without a problem, thats what i use, i havent ever tried using gear oil mostly because 10w30 has worked and i try not to fix anything that isnt broken.
