Hey guys,
I am about to go for a ride on my trike in the bush with some mates.Now my trike is running a bit rich,and is idling a bit low.
The trike is a 83 200es.Could someone tell me where the idle speed and air/fuel mix screw is???
Cheers.
Hey guys,
Cheers.
82 ATC 200...Getting torn down for resto/cleanup
Looking for a "sport" trike in New Zealand..
The idle screw is the horizontal one on the right hand side. I would not touch the air/fuel screw unless it's been played with already.. the air/fuel one is the vertical one between the carb and cylinder that's .. under .. the carb.
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
On most of the Honda 200's that run rich I have found that it is wear in the needle seat of the carb(on the slide). Try raising the clip on needle one notch. This will lower the needle into the seat. This should help but it should be replaced with a new needle and seat.
1985 Tiger 250LC
1985 Tiger 200LC
1985 ATC 350X
1985 ATC 200x
1973 ATC 70 (resto project)
and many more!!!
Blue Line Graphics
Thanks guys....
I went out to adjust it,pulled the pull cord and guess what?It's got no compression![]()
