Results 1 to 11 of 11
Thread: Replacing loose ball bearings on the top of a Tri-Z steering neck with a tapered set
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Anyone ever did this? Mine has alot of slack and play in that particular area. I dont like the loose ball bearing setup to be honest and like the idea of a nice tapered setup just like whats in the bottom alot better.
    Live Oak, FL
    15,069
    Also...Its time to replace the swingarm bushings and bearings. Never changed them on a Z before. Any aftermarket sources or just OEMs?
    Front royal, va
    2,186
    for the swinger , oem is all thats out there, and they aint cheap, like $70 for the seals, cups and bearings, and i dont know on the tapered bearing setup, mine havent got any slop in them in 20 years.
    May 2003
    Houston, Texas
    2,409
    tighten up the main bolt on your triple clamps or neck.
    You may be missing bearings. Still have the originals in mine and merely greased em up. They are tight as heck.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Mar 2004
    North Central Ohio!!
    2,712
    I hate swinger bearings. Their all terrible designs. Why would you put unsealed bearings in with no grease zerks? The last set I put in the Z lasted 6 weeks. I since went to hand-made brass bushings, the full length of the swinger, not just the outside like the originals. Mine are just now in need of replacement and lasted since last february. I think the next set I make will have grooves for grease and I'll add a grease zerk to the bolt.
    I guess the same principal could be applyed to bearings. Just never had any luck with them in that area.
    I just had to cut out a swing-arm bolt from a 2001 Warrior. That was a horrible design. Running the bolt thru a 12" long steel sleeve. Nahh, it will never rust together. Duh...
    Live Oak, FL
    15,069
    I think I am missing some of the loose ones...How many is it suppose to have, full circle so theres no gaps I'd guess? $70 is pretty freaking steep sounding for just a handful of little needle bearings...Maybe I'll do what Derrick did and make some brass bushings. I did just install one of Ronnie's stainless swingarm bolts.
    Nov 2004
    Waterloo IL
    2,701
    I'd probably just stick with what you have. You shouldn't have a full circle on the bearings. A full set should actually look like one is missing. Just get them from the dealer they are really cheap and probably in stock. I just bought some for my 1976 Yamaha TT500. It takes 3/16" ball bearings on the top and 1/4" ball bearings on the bottom. As far as swing arm bearings, I used Richards bushings on my 250R, they are awesome!
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Rittman, Ohio
    6,276
    The swingarm bolt is hollow, so I plugged one ned, put a grease fitting in the other end, and then drilled two small holes right where the bearings would sit. You not only can keep them greased but you can purge the crap out after each ride.
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by TimSr
    Damn, that is an awesome idea!
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Newfoundland
    5,280
    Take her to a metal shop, they should be able to hook you up with a race and needle bearing for the top of your steering neck. I'd rather do it once the right way as opposed to twice the wrong way. I also have brass bushings in my swinger, great design.
    na
    5,702
    my banshee was eatin up swinger bearings. so i went to delrin plastic ones.they been in there a year and are still tight.they are 25.bucks.plus they are easy to remove when they need replaced.no more grindin races out. i held the z ones up to the banshee ones i have, and they were the same size. i can get a pic later if someone wants to see them. i think there are 17 balls in the upper race.they are 50 cents each. these specs are for 85 tri-z. unsure for 86 tri-z sizes.
    Proudly NOT a member of
    "Team on the Teat"
