will a honda 83-85 atc 200x front wheel assembly fit on an honda atc 85-86 250r?
No
The spacing of the lug nuts is different. The hub is different too.
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
Only possible if you use the complete 200X assembly... ie hub, and rim. Then not even sure if the rotor spacing for the brake would match up. If you are looking for a chrome rim, use a 350X rim. They have the same bolt pattern as the 85-86R
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
if i use the 200x rim and hub assemble would the spacing for the 86-86 250r work...i already have a 200x front rim all i need is a hub ie it will work. trying to use parts i've got. if it won't work then i'll spent the money.
Maybe if you swapped everything down to the axle? It would be easier to tell then because there are fewer measurements. I have an 86 R and can measure the axle mounts.
please do and let solve this question and help others...
