Thread: premix only oil in a sleds injection system
    Jun 2004
    potsdam ny
    1,227
    i was wondering, what would happen if you used premix only oil in a sled that has an injection system? i am guessing it has to do with one of two or possibly both of these things, 1, how thick it gets when its cold, or 2, that premix oil HAS to be actually mixed with gas to lubricate correctly...im not sure, maybe premix oil can get varnish-y like gas or something, idk...thought id throw it out there....
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    I believe its the flow rate. Get a good injection oil. I run klotz synthetic injection oil. The oil has to be able to flow at colder temps.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    rustbucket is offline At The Back Of The Pack Arm chair racerFirst time rider
    pentwater michigan
    180
    seems like it has to do with how thick it is or viscosity. I remeber my suzuki bikes had injection and they called for 30weight suzuki cci oil. It also has to do with how concentrated it is. with premix you want as much lubricant in the oil. because you can't mess with it after you dump it in. but with injection the amount of lubricant is controlled constantly by throttle position and engine speed.
    1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
    1981 trimoto 125
    1971 suzuki ts 185 it will spank a 200x
    1966 gmc 3/4 ton
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    okay...lol well i have had sleds for ever, i had a indy 600triple liquid. that turned into a 440.. and now is a 500 bored over, and i just piicked up an indy 400 liquid, i also had many other sleds when i was young, my advice. Pre Mix ONLY. it wont hurt anything my sleds have injectors. but when they fail.. well your Effed. my buddy had a aritic cat 440, injector fialed, and the sled siezed up. So use premix only!!
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
    Sep 2005
    Lipetsk, Russia
    2,824
    Most of the 2-stroke oil I've seen has been labeled "Premix/Injection oil" so I'm guessing it should work fine.
    Jun 2004
    potsdam ny
    1,227
    try using castor 927 in your sled and tell me how it turns out
