Results 1 to 15 of 23
Thread: 13 0r 14 tooth sproket for 250r atc
    Oct 2005
    SACRAMENTO CA
    25
    Arrow 13 0r 14 tooth sproket for 250r atc
    14 or 13 tooth sproket is their a big diffrince?
    Jun 2003
    englishtown NJ
    2,676
    yes, use the 14, gives you more top end, if you are doing woods, tight:13, kinda open and mx:14 I use 14/38 on my mx r, but thats with a crazy motor that can pull 15/36 if needed, my woods r I use 14/39. I would use 14/39
    2strokepwer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Mississippi
    359
    14 and yes there is a difference. I use a 15 tooth sprocket in the front and 36 tooth in the rear.
    2 strokes feel the power
    Jun 2003
    englishtown NJ
    2,676
    what do you have done to the motor to pull 15/36?????? I have a 310pv and everything else to go with it, I find my 250r is fast enough for mx using 14/38.
    May 2003
    Mississippi
    359
    Quote Originally Posted by deathman53
    I don't have a bigbore but I have a good ported cylinder and everything else to go with it.
    breastman569 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    Tucson & Mesa, Arizona
    272
    i went from a 13 to a 14 and love it and wont go back you dont even have to add a link just adjust the swinger a little. do it you will notice about huge incress in ** top end.
    Phoenix, AZ.
    6,719
    If you ride dunes use the 13. Otherwise you probably won't be able to pull 6th gear in the sand unless you have a really pumped up motor.
    May 2003
    Mississippi
    359
    Quote Originally Posted by Dammit!
    the closest dunes to me are 14 hours away and if I ever get to go I will change my sprocket setup. around here there are trails, fields, hills, and drag strips. I wish there were some dunes near me. I would be there every chance I had.
    Mike Fort Laud's Avatar
    Mike Fort Laud is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2002
    386
    On my 250R I run 14/36. It has great top end. Down here it is all flat and I have to outrun the 4 strokes.
    I would rather have a sister in a whorehouse,than a brother with a quad!!!!!!!!!!!!!!!!!!!!!! Still walking the "Tightrope"
    NE Arkansas
    2,344
    I got a 12/39 now. Last night I ordered a 13 and 14 of Rockymountain, they are running a closeout on sprockets, these I ordered were $5.99 and 6.99 a piece, also got a few of the "Y" wrenches with 8mm,10mm, and 12mm sockets for $.99 on closeout.
    Man, a 14/36 sure is tall, dunno if mine has the balls to pull it, hehe. This is a TRX chart, but should be the same for an ATC. Just for estimated speeds of course.
    http://home.earthlink.net/~gellett/250r.htm
    My Rags
    Richland WA
    808
    Dang good price on sprockets, even if theyre plain steel.
    Make sure that front sprocket is on the right way, there is a backwards on my Sunstar and they didnt say so. I found out the hard way... The sprocket is offset a little to one side and the chain runs crooked.
    At some point, the sprocket and chain get tough to stuff in the chain guard, but DONT take it off, thats begging for a busted left side engine case if the chain lets go. My engine has a huge welded spot to prove it
    Im running a 14/36 sprocket ratio on a stock 250R engine and first gear is still useless - it makes too much torque.
    Jun 2003
    englishtown NJ
    2,676
    on most modded r's 1st and second are useless, on mine I could pull 3rd gear holeshots, I don't, but I can,
    3leggeddog's Avatar
    Nov 2004
    i run a 14/36 with 18 inch tires for mx,and trail ridin i go 12/36 with 20 inch tires.what size tire do you run?when you go from a 18 to 20,or a 20 to 22,it's like going up or down 1 tooth on the front sprocket.
    NE Arkansas
    2,344
    Can the case saver go on with a 14?
    My Rags
    Richland WA
    808
    Mine would if the chain hadnt ripped the mounts off the case! It looked a little tight at 14, but I havent measured it.
