Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: 13 0r 14 tooth sproket for 250r atc
    2strokepwer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Mississippi
    359
    My case saver goes on with the 15 tooth
    2 strokes feel the power
    Jackson MI
    1,688
    Yes you can use certain case savers with a 14 tooth sprocket. I can't say they will all fit. The one I have will work well with a 13 or 14 tooth, I think the 12 would tangle the chain with mine. I run 12, 13, & 14 tooth sprockets on mine, with 20" tires & a 38 or 39 tooth rear. It all depends on what kinda riding I will be doing. I like the 12/39 for tight woods or quick accelerating, 13/39 for normal riding & 14/38 or39 for fast riding.
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by 2strokepwer
    What kind of case saver do you have? I need one of those, my 250R has stock gearing and I think even 2nd gear is too low for most things and first is about like the low in a 250 big red!
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Anaheim
    1,270
    13/38 or even 12/38... i rather be quick then fast....
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    May 2003
    Mississippi
    359
    Quote Originally Posted by Blown 331
    I use the factory one
    Jun 2004
    Oregon
    1,783
    im running 13/38 myself and i cant pull 6th in the sand..Would it help if i went to a 14 in the front? or leave the front alone and go to a 42 in the rear. Im not to sure witch way i should go..Maybe i just need to deal with not being able to pull 6th lol i dont know.....
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Sep 2003
    Elizabethtown PA
    1,581
    they make the billut aftermarket chain gaurds for either a 13 or 14 tooth front sprocket. they are shaped slitely different.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Michigan
    1,220
    I want to see a pic of that. I run a 15 and theres no way, no room for the stock case saver unless your talking about the outer chain guard.
