Results 1 to 11 of 11
Thread: point timing? for my us 90 (pic included)
    Front royal, va
    2,186
    here is the pic, i know the gap is 12-16 thousands, where do i line up the 3 marks on the cam?, and which is advance and retard ?, please point them out, this thing keeps carbon fouling plugs. i use the d8ha recommended plug
    Aug 2004
    Ab Canada
    4,368
    You talkin about the point plate? the mark on the top looks real close, little retarted maby.....line on the Mag lines up horizontal for timing..
    1985 Tri-Z-
    Jun 2003
    South of Rochester, NY
    3,470
    I just won a Honda NOS 1970 US90 shop manual. When it comes, I'll scan you some pics.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Front royal, va
    2,186
    thanks bud, i can use a copy!
    Oct 2005
    MO
    20
    take a look here, first post has a scan of the instructions for setting timing on the 70, 90, and 110
    http://www.glamisdunes.com/invision/...howtopic=56887
    Front royal, va
    2,186
    thanks 79atc110!
    Jun 2003
    3,470
    Quote Originally Posted by 03 ORANGE SHEE
    thanks 79atc110!
    Hey... I got a 1974-1979 ATC90/ATC110 manual now.... the 1970 US90 Service manual will be here Friday. Oh... I got that pipe today... thanks! It's a much smaller diameter header than the reminence on my US90. Either way, I'll take it down to the muffler place and see what they can do. I got a 83 110 pipe that's all rusted into like 3 pieces, but I think I'll see if the spark arrestor can slide into that pipe you sent me. Just let me know how to settle up with you on the shipping.
    Bruce
    Oct 2005
    Vicksburg, MI
    73
    Was reading the link above about the light to set points. The guy said you really have to watch the light because it doesnt go out, only dims. Seem like you could do the same thing with an ohmmeter. Never tried it but seems like same thing only instead of watching dimness of light your reading numbers.
    Oct 2005
    Pennsylvania
    863
    It will be a DRASTIC difference in light, so it isnt that difficult- Basically turning slowly (By hand ) and watching marks. Yes an ohm -meter works just as well.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Richland WA
    808
    "when the points open I expected the light to go out but that is not the case. The light merely dims, it does not go completely out."
    The battery is feeding through the ignition coil to ground most likely, disconnect the coil and the light should go completely out. If not, somethings wrong.
    Oct 2005
    Pennsylvania
    863
    Quote Originally Posted by TeamGeek6
    Exactly right--If you "Unground" the coil, the light shuts down completely. The dimness is caused by "Feedback" thru the coil
