Originally Posted by
blue27
Plug the lines golf tees, but use two different colors so it looks cool,I wouldn't recommend nuts and bolts, you don't wank a spark. But I would call alocal radiator repair shop sometimes they can cook the tank out for you but you will lose your paint, just an idea.
Fill the tank with soapy water ( I use dawn dishwashing soap )
before adding the nuts and bolts
This is as recomended by Kreem as a pretreat.
http://www.pro-flo.com/chemicals.htm#Kreem
you can also use the rustol for rust removal
On edit:
After shaking nuts/bolts with soapy water , rinse and empty all water possible then follow with a rinse of acetone to remove any moisture that could further rust the tank. The kreem product works well, kinda a pain but it does the job, I also add inline fuel filters, the micro ones from Dratv .
2- 1985 atc 70's
1- 1984 atc 70
1- 1986 atc 250R
1- 1987 trx 125
2-2002 400ex's
1-2002 CR250
1- 2003 500 Predator
2001 PSD 4X4 Crewcab
2006 LE 3505
