Results 16 to 30 of 47
Thread: UPDATE: why wont it start!
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    so how do i stop the flames? im afriad of this and guys the compression is there so i dont think its the key thingy
    400exXx's Avatar
    400exXx is offline Formerly: 05 200c Blasta Arm chair racerNew to the board
    Nov 2005
    New Orleans, Louisiana
    82
    what did * put in it and where did * put it.
    2002 400ex
    JE - Cometic - Hotcam - Curtis Sparks - Twin Air - Procom Magnum - Razr - Kenda - Primary Drive - Dynojet - Fly - Houser
    TCS soon
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    starting fluid and a bit of gas in the carb hole when i took the carb off but i just put carb back on it i pull it again will it get on fire agian?
    400exXx's Avatar
    Nov 2005
    82
    isnt starting fluid for the sparkplug??? try to get the starting fluid out with gas maybe thatll work
    2002 400ex
    TCS soon
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    put ** carb back on , if ** carb is on there no flames will come out, basicly put it to how its supessed to be, what they trying to tell you is, have your trike all normal, take a socket and rachet and take out ** spark plug, put some gas in a 2 liter cap full, now put your spark plug back in and have the kill switch on. start pulling the pullstart a few times and see if she starts for a few secounds. If you say you had it running fine until you change the float, why dont * put it back to how it was and see if it runs then. Also check your vavles, and timing.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    400exXx's Avatar
    Nov 2005
    82
    run gas thru it about 5 times and it should get the starterfluid out
    2002 400ex
    TCS soon
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    run gas threw it?? what are * talking about and where do i do this?
    Brandon, Manitoba
    2,209
    What I would do if the cylinder is full of starter fluid is take the plug out and crank it over a whole bunch of times, get it all blown out of there.
    Then put only a few drops of gas down the plug hole, put your plug back in.
    Make sure your carb is on.
    Pull start it, It SHOULD fire, you said you were getting compression and spark, right?
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    so it wont catch on fire if the plug isnt in??
    Brandon, Manitoba
    2,209
    No, it wont, as long as there is no ignition source(spark plug), or very high compression (which there isnt), it wont.
    Jan 2005
    RI
    2,530
    if theres nothing to ignite it, no, it wont catch on fire...common sense anyone?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    lol im sorry i am new at this and thank you for the common sense check it was need lol............
    Also thank you every1 that tryed to help out this afternoon in about 3 hours im going to work on it with my dad
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    but with this doesnt that mean the spark is good so its not a wire problem right!!!!!!!!? if so that made my dad 1 less thing wires ahh!
    Richland WA
    808
    Ya cant run it without a carb, itll do all kinds of strange things. If it caught fire, there was WAY too much liquid put in, just a tiny bit will do.
    "but with this doesnt that mean the spark is good so its not a wire problem, right!!!!"
    No, it doesnt mean the spark is good. It only takes one spark to ignite starting fluid, but for the engine to start easily and run right, the spark has to be the same every time, and good and strong every time. Once isnt enough.
  15. #30
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    no im saying i pull it many time and spark is there so its not electrical and its not ignition!! so wtf is my porb? can trikes not start in cold weather???
