Results 46 to 47 of 47
Thread: UPDATE: why wont it start!
  1. #46
    Jan 2005
    RI
    2,530
    my bet is that you messed something in the carb up, most likely the float that you replaced...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
  2. #47
    Jul 2003
    Ontario Canada
    813
    maybe you should take it to a certified mechanic, all were doing is shooting in the dark, I have a hard time reading some of your posts about your problems, mainly because you use poor grammar and spelling, run-on sentances, etc...
    I honestly think you should just load it up and take it to a mechanic, just tell him to do an estimate on it. When I do estimates at work, it takes me 15-25 minutes, so its about 30 bucks for an estimate (60 bucks an hour) It takes me, or the other mechanic about an hour and a half to fully clean the carb, that is letting them soak, complete disassemble, thorough cleaning, replacing any worn parts, and putting back together, and tunning.
    With that said, if I was doing this at my shop, I would be charging you about 120.00 for the estimate, carb cleaning and tunning on the machine, plus an overall check of vavles, intake rubber, bearings, brakes, etc...
    Curtis
    Currently Trikeless- but I have a LT250R
