Thread: Hard shifting, whats the cause?
    Nov 2002
    Kirkville, NY
    3,831
    Ever since I bought my big red in the spring I have noticed that it is hard to downshift, mainly from 1st to neutral but sometimes from 2nd to 1st. Several times I will have to almost force it into neutral or give it a little gas when sifting into neutral. I have tried adjusting the clutch but that didn't seem to help. Oh yeah, the trike is a 1983 Honda 200e. I bought it from the original owner, an older guy that I know. It does not have too many hours and has spent most of its life doing yard work. It is basically stock and the engine has not been apart.
    Any Ideas?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Richland WA
    808
    Having to gas it to shift it does not sound like clutch dragging, usually that takes reducing engine speed or shutting the engine off. Sounds like internal transmission problems, but Id have no idea what. Since its in 1/2 gears and not the rest, that might indicate which parts to look at.
    phreakboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Coatesville,PA
    358
    One of my old 200s did that when it was A)low on oil, B) cold with too thick of oil.
    1971 ATC90
    1984 200s
    1983 Autox
    1985 200x
    198? Yamaha 125
    (2) 1985 250sx's
    1974 Trail 70
    1991 Honda Cub90
    1974 Yamaha 125 Dirtbike
    1972 Kawasaki 175 Dirtbike
    (2) 1980 Chrysler Sno-Runner
    (7) 85-87 Toyota Mr2s
    (2) 1985 Dodge Ramchargers
    1968 Mustang
    1972 Beetle
    2004 Dodge Ram 1500 HEMI
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    sounds to me like a bent shift fork which may or may not include broken or worn dogs on the frewheeler and or slider gears,possibly worn shift drum ,also may have a broken or bent shift detent .the detent may or may not be fixed by removing the outer case im not too familiar with the 200e but the shift fork,drum,and slider and freewheeler gears are in the motor accessable only by splitting the cases
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
