i can't seem to find the culprit. i've cleaned the carb, idle jet, main jet, moved the c-clip up and down on the needle. i moved the c-clip all the way to the bottom, lean, and it runs alot faster, but still hesitates. drained the tank, and put fresh gas in, has good flow through the petcock. i've screwed the idle screw all the way in and all the way out, and everywhere in between, and it still hesitates between 1/4-1/2 throttle. i havn't touched the pilot screw, because its frozen, and i'm afraid of it snapping off. whats the problem here? thanks
