Results 1 to 7 of 7
Thread: blown lights
    dooner17 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    NB
    293
    blown lights
    my headlight hi-beam and taillight burned out, now all i have is low-beam. What would it be bulb"?
    Howdy's Avatar
    Celina, Ohio
    10,079
    If you still have low beam, then there is a very good chance it's your bulb. Now it could be a wire become disconnected, but this generally isn't the case.
    Howdy
    Oct 2005
    Pennsylvania
    863
    Probably bulbs---
    But...................Dont forget to think about why they both burned out at the same time---A voltage spike from your electrical system can pop bulbs -and so can sheer coincidence---Just food for thought.
    What is it???? (Type of trike)--Are low beam and Tailight on continuously while trike is running?
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Jan 2005
    NB
    293
    it's a 200s. i drove in town and they worked perfect. Hid it in the bushes behind the arena and when i left I started it and they both went out. Swithced it to low bam and it came on. I have a puch moped and if one bulb goes none of them work. Could this be the case for the taillight?
    Oct 2005
    Pennsylvania
    863
    I just looked at the wiring diagrams-----Just for laughs---Does the tail light come on with the low beam position?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by dooner17
    No it wouldn't be the same. I have had machines where only the tail light or only hi or only low beam worked.
    Howdy
    Jan 2005
    NB
    293
    ok ill check the bulbs tomorrow. The taillight does come on with low beam. bit not anymore/.
