Hey John, WELL....it took some time and patience with a dremel tool and I had to cut the bolts off the bottom of the control switch and reposition them back on to line up with the 2 holes that the Honda tab cover went in...then I had to wedge my fingers in there to put the nuts on the bolts to tighten it down because you have to tighten down the ignition console before you mount the switch-which in turn covers the two screws that mount down the ignition console...took some time but it was worth it
I'll take some close up pics for you soon of it-
Patrick
1985 Yamaha 225DRN w/OEM headlight guard, footboards, front rack, rear rack, work light, brush guards and trailer hitch
