Results 1 to 15 of 17
Thread: Picked up a Tri-Z and Tecate today..pics
    Nov 2004
    Atlanta TX 3-states area
    1,592
    The Tri-Z is the one that I posted the pics of a few weeks back. Here's a few more shots of it anyway. The Tecate is an 84 red model. My brother took this one, he was needing a new ride and this one fit the bill great. Can anyone tell us what kind of pipe this is on the Tecate?? Oh, we picked both of them up for a smooth 400 bucks
    Attached Thumbnails Attached Thumbnails Tri-Z 1.JPG   Tri-Z 2.JPG   Tecate 1.JPG   Tecate 2.JPG   Tecate 3.JPG   Tecate 4.JPG
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    Nov 2004
    1,592
    One of the Tecate Silencer
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    That Tecate pipe is cool looking...I'm almost positive its not a stock one, because they were completely stamped and not a sectional style like that one. It might be a Jimmy White replica Bassani, or a PSI pipe. Not even sure who all made Tecate pipes to be honest.
    Nov 2002
    Kirkville, NY
    3,831
    Boy, that tecate is colorful, looks like you have some nice projects though. Good luck
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    May 2002
    Texas
    2,670
    Might be a Bill's pipe. I had a round black steel silencer on my 84 that was a cobra silencer.
    One other interesting thing is the Tecate looks to have 1986/87 OEM rear tires. And the aluminum front rim it has is nice as the OEM one was gold painted steel.
    Good price for those two trikes!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Jan 2005
    Great Bend
    704
    hey lomax you may wanna tell your brother when he really starts to look over his ride check out the tabs that the bearing carrier sits in. A1 and A2 tecate were notorious for bending those tabs to one side form the engine pull.
    to prevent that from getting bent after being straightend is take it to a machine shop that can weld aluminum and have them weld on another tab on the opposite side of the original and use another chain adjuster and it will not bend again as both side are held tight when adjusted.
    i know this cuz is the same way and I have to it fixed.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Rancho Cucamonga, Ca
    228
    The pipe looks like a bassani, a tecate in my area has one that looks just like yours. Have fun with those!
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    Nov 2004
    1,592
    I will let him know about the tabs on the chain adjustment system. Thanks
    On my Tri-Z the front fender, rad. shrouds, headlight shell and airbox cover are in PERFECT condition other than needing a little "brighting". I hated to go Maier or use a less than perfect set or originals so after a little searching I turned up 2 sets of rears in black that are brand new in the package.
    -Will
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    cedar falls, IA
    546
    if you can get a pic of that pipe all in one picyure I could tell better if its a bassani or not. I have 5 different aftermarket pipes for that generation of tecate and all are very similar but, a bassani pipe uses a straight silencer whereas the others use a silencer with a slight bend where it connects to the stinger. its kind of hard to tell from the picture if the silencer is angled or not. as for my pipes i'm not sure what they all are except for the dg and the bassani and maybe a wheelsmith.
    Joe
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
    Nov 2004
    1,592
    Its perfectly striaght from one end to the other. In fact, the silencer is only about 13-14 inches long if i remember right. It could be a little shorter or slightly longer.
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    arizona
    550
    nice find man!
    good price too, although id either repaint or replace the green fenders on the rear.
    someone on here a while ago had a vented number plate for the 84 tecate, it cleans up the whole front of the bike, personally i love the look of it with the plate.
    i wouldent mind owning one either, they look like a blast on dirt roads for sliding.
    Newfoundland
    5,280
    The arse on that T3 look wide to anyone else?
    Minnesota
    49
    LOL, I love the race bend on the brake lever.
    -sb
    Nov 2004
    1,592
    Quote Originally Posted by BigGreenMachine
    The rearend of the Tecate actually isnt as wide as the rearend on my 350X. I think outside tire to outside tire was 47 inches. I think setting next to the 200x kinda makes it look on the large side.
    -Will
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    Jan 2005
    Great Bend
    704
    the low pro fenders also make it look wide as well.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
