I bought a 200 honda and it has no spark.I also have a 82 185s so I changed the coil or box that the spark plug wire goes to with the one form the 185s and that didnt work so then I took off that cover that says cdi or the little cover that the 2 bolts are holding it and 2 wires run out.There a little black box with two wires i changed that that didnt work.Im not familiar with all the iginition parts on these three wheelers is there any digrams that I could look at that would tell me where and what the parts are any links i could go to.Now under the pull rope theres iginition parts in there to right.What do i look for or what could be wrong in there.
THINGS I TRIED
different plug wire
the box the spark plug wire goes to (coil I think)
Under the cdi cover that little black box with the 2 wires changed that looks like a relay.
WHAT SHOULD I TRY NEXT
