lookin super nice blazer. almost gonna be to nice to ride once its done.
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
The new White Brothers springs and the custom spring in the rear sure made a difference, its not all mushy like it used to be. I can't wait to take it out for a spin. I also installed 2 1/2 inch spacers in the rear also.Originally Posted by ATCWRENCH
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Blazerone always puts out top-notch work!!!!
http://www.radmfg.com/
Used to make them about 4 years ago. He said they might make a batch if they got an order for 10-20 of them. Im down for one, any other Takers on a Billit Rear Bearing Carrier for your 84-85 Tecate?
I see alot of Sweet Tecates on this thread that could use something like that. Buy em or lose them forever. He said they may even have the Drawings of the 84-85. I may ask to buy them and have them machined by someone. It would be nice to have blueprints of a Part like that so one could be made whenever someone needs one. If not there wont be many Tecates around 20 Years from now.
$1,400 for 10 of em to be made. Thats a little less than $150 each. We need at least 10 people who will want one for the 84-85 Tecate. Same with 86 Im sure.
84-85 Custom Tecate
1986 Honda 200X Daily Rider
2006 Suzuki King Quad
Can't believe what you've done with Jen's ol'T3. Thats amazing looking. The silencer is going to sound knarly too!
Meat, buy the blueprint for it. I can't swing $180 just yet.
I think the stock tecate carrier is pretty strong. Ive never broken one or scene a busted one, so other than the aesthetics i cant justifiy the price.
Originally Posted by 3Razors
Me either... but the double row bearings would be nice.
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Well I slapped the tank on there and fired it up, sounds good, I wish my rear fender would show up already...
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Looking good man. Bet teh pipe sounds awsome.
You have the same tank fade as us green Tecate owners. Chain tensioner doesn't look quite right though, top chain run needs to be pulled down on the sprocket.
when you striped the paint off your engine, did you polish it or is that natural aluminum with a clear coat on it? I love the way it looks, i want to do the same thing to my engine when i get around to rebuilding it.
I friggen sounds awesome, I might just run out and fire it up again. lolOriginally Posted by BigGreenMachine
Cliff its just lightly polished, the cylinder is just stripped. I don't clearcoat because the stuff seems to chip and flake. I clean my bikes up good after every ride anyway....
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Lookin' great! Got a question for you though, could you take a pic of the front master cylinder/throttle for me? I have had no luck finding a good master for mine and I am trying to use ones I have around here from some MX bikes of mine and assorted other rides. The problem I'm having is is that where the throttle cable comes out of the throttle runs directly into my master and I can't find a combo that works quite right. Thanks
The stock master gets in the way pretty good too 90nut. I've tilted my throttle housing back behind the master cylinder so that it all just clears each other.
James
If you need a better one hollar, mine has a new motion pro twist throttle though.
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Blazer, what kind of fork boots did you use?
