Does anyone have a suggestion on how to remove one of these by cutting it out without haveing to cut the swing arm? Im totally lost as to how to do this.
make sure you chain tensioners are loose, actually remove them. use a old axle if you have one or a large punch, take you time and don't screw up you threads, try wd-40
Use a torch and put in a lot of heat, then carefully pound it out.
1985 Tiger 250LC
1985 Tiger 200LC
1985 ATC 350X
1985 ATC 200x
1973 ATC 70 (resto project)
and many more!!!
Blue Line Graphics
The bolt in it is stripped anyways ive got a new one so it doesnt matter if it gets mess up. The bearings are on the edge of the swingarm right? It looked like there were in the manual but i coudlnt realy tell.
Yes the needle/roller bearings are on the extream ends of the swing arm on both sides.
john
lots of heat is the only way and a bigor air
!!!! trust me on this one. heat is the only way if the bearings have never been replaced.
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
If you want to sawsall it you cut the dust cup seal like your tring to make a washer out of it that way you cut thow the bushing and not the swing.
Or if you can get it to move a little you can spred the frame so you can cut just the bolt.
I never thought of spreading the frame ill try that and cut it out hopefully that works. The heat wont hurt the cases or the gasekts will it?
Cut it with a sawsall not torches. spred the frame just enuff to cut the bolt.
Don't want to spring the frame.
