i know some * guys on hear use the cr head gasket on the atc250r's (waterpumpers).... i was just wondering wats the advantage of using the cr vs the atc250r?
what year cr250 head gasket do * guys use?
We use the thin ones for a cheaper"more compresioned" engine,unless you can get somebody to do your head for you ... Part No. 12254-KZ3-000..... I Can't remember the year CR,i think it was 86 or 88 ? ...
Ronnie
"07" DR650 Suzuki Dual Sport
Dirtbike, I had my ATC head milled about 18 years ago for extra compression while still using the stock ATC head gasket. Then about 16 years ago, I switched to a CR cylinder and have been running the thinner CR headgasket which increases compression even more. I use a 1990 CR headgasket.
I used a ATC gasket but ground the rivets and threw the steel center plate away and use just one thin layer. It's much thinner than the CR gasket and you also get 2 gaskets for the price of one. Runs fine on pump gas too.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
Yep, just that it wont seal like the original gasket, so the head and deck have to be nice n flat, and torqued carefully.
Hey BLOWN ... ive done that MANY of times ... 2 for one ... then i spray that copper stuff on the one side
