Well ive had a string of problems and it is a long story and I need help so here it goes. And i own a 125m
Well my trike felt boggish so i took off the carb to find out what was wrong with it, and there was frozen gas in the gas filter. FIXED THAT.
Put carb back on and then gas started leaking out of the airbox so I took off the carb again and took off the float housing/ chamber repositioned the float and needle and seet then put carb back on. FIXED THAT
Once I put the carb back on I then tried to start it, the dang thing wouldnt start without choke on. Once that happened I plugged off the gas lines and left it for 3 days because I the got a cold. I then took out the gas filter today to make sure it wasnt frozen (it wasnt frozen) so I then put it back together and tried to start it and it wouldnt start at all! Then gas started leaking from the nut/bolt that closes/seals the gas filter off. Does anybody have any ideas why it wont start or why it is leaking from the bolt/nut/.
I hate to make it so long but i wanted every detail in just in case that makes a difference sorry, any info will help and thank you very much!
_125m_
not running yet. but won't be long.
