Results 1 to 15 of 17
Thread: Yamaha Bravo Project
    Newfoundland
    5,280
    Been working on my little Yami as of late. Its a real project in every sense of the word. Doing a little restomod work on it trying to make it a better ditch banger. Since its been mine I've replaced the slide rail suspension with new pieces, bought a couple new heavy duty skis, rebuilt the top end (found a melted piston), put on a new track and replaced the bars with the BMX bars from my Dirt King.
    Last winter
    Bars
    Right now the sled is torn down to the bare body so I can straighten and pound out every dent and curve, pop rivet/weld the sheetmetal back together with thicker/longer rivets and brace the body where needed.
    Cut open the stock exhaust and opened up the passageways with the drill as well. When I had the head off I cleaned up all the ports so everything flows smoothly. Need to check what bottom sprocket I have as there are several options for more top speed or grunt, want more grunt.
    Little holes
    I mean there must be room for improvement?
    Big holes lol
    Should note that I have a stock exhaust as well just to compare what works better. Stock pilot is a 78 and the stock mix ratio is about 20:1 so with the exhaust opened and the mix at 30:1, I think I'll notice a gain. Also hoping to get a better sound.
    Also removed like 5 pounds of worthless crap like the oil mixing system, odd brackets, windsheild, rear rack, etc... Fun little project, made a headlight cover from a crazy carpet yesterday and have some number backgrounds to put on as well. This is just a simple project, just for fun, no big money spent and don't plan to spend much more. Looking for bar hooks and handguards as well.
    Riding pics from last winter. My buddy stopped for a tree when I was trying to power over some deep snow, small trees.
    James
    Goderich, Ontario
    125
    I have a 1995 Bravo in mint condition (maybe 1000km) that my kids ride. Here is a picture.
    Good luck with your project!!
    Newfoundland
    5,280
    Looking for a bigger then stock carb, needs to be a spigot mount 32mm. The stocker is a 28mm Keihin.
    Oct 2005
    Escanaba michigan
    72
    i have a bravo... i had it when since i was 7... i love those little machines
    Goderich, Ontario
    125
    How do you figure 30:1 will gain you anything? How much experience do you have with 2 strokes?
    Newfoundland
    5,280
    Enlighten me Rusty, I think I know where I went wrong here. 30:1 is a richer mixture? So really 20:1 is leaner?
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by BigGreenMachine
    30:1 is a leaner mix. That's 30 parts fuel to 1 part oil.
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by OldSchoolin86
    Actually depends on what your talking about. Yes 30:1 is leaner on oil but richer on fuel. The 20:1 can also be leaner if your talking about the amount of fuel.
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    May 2002
    3,658
    Quote Originally Posted by slothminx
    I think it's pretty safe when talking about mixing oil in to gas that richer or leaner can be reserved for the oil content.
    Newfoundland
    5,280
    Yes so wouldn't 30:1 give a better burn then 20:1 Osin86?
    Aug 2004
    Ab Canada
    4,368
    You will probably Notice a bit of increase in Throttle response, Less fouled plugs and cleaner running, i would just go 32:1 and call it good.
    1985 Tri-Z-
    Sep 2005
    Lipetsk, Russia
    2,824
    Wow, those Bravo's are pretty small, eh? Looks like a nice berm-basher machine though, probably bad for your back (looks like no rear suspension)... One of my friends has one, I should see how much he wants for it.
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    I would just stay with the 20:1 mixture, unless you want to rejet for a different mixture, It will run slightly richer with a 32:1 mixture.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    elliot lake, on
    30
    I had a 1983 bravo up untill this past winter, the thing never let me down. My dad bought it for me and my older brother when i was about 9 and my brother never had any interest in it so i was always riding it and working on it. Before last winter my dad left our familly and the ownership was givin to my brother for some reason because he is older them me. What does he do... he sells it and dosnt give me a damn penny. That'd when I went out and bought myself a 88 enticer which is also a hell of a machine.
    Newfoundland
    5,280
    Bump
    Got a newer Bravo body and will be putting this thing back together sometime soon. Can't wait for the snow to fall.
