Results 1 to 15 of 19
Thread: how do you fix a stripped out drain plug?
    Jun 2004
    IL
    67
    my dad has a 250sx and the drain plug hole was stipped out when he got it. and i was just wondering what would be the best way to "fix" it? The hole isn't completely smooth but the new plug we got just slides all the way in without having to turn it. any thoughts?
    1983 Ford Ranger 302 4x4
    '04 TRX450R
    '97 trx300 4x4
    '93 trx300 4x4
    '08 700 grizzly 4x4
    '87 trx250x
    '85 atc250sx
    '85 Tecate x2
    '85 '83 '79 atc70
    '85 atc200s
    '85 atc110
    '83 XR500R
    '77 '79 XL75
    '73 xr75
    '96 kx100
    '80 JD spitfire x2
    '88 terrapro
    2 JD gators
    Jul 2004
    Mud hill. close to water !
    3,658
    Heli coil !
    Currently :
    Jun 2004
    IL
    67
    i didn't even think of that. that should do the trick. thanks
    '04 TRX450R
    '97 trx300 4x4
    '93 trx300 4x4
    '08 700 grizzly 4x4
    '87 trx250x
    '85 atc250sx
    '85 Tecate x2
    '85 '83 '79 atc70
    '85 atc200s
    '85 atc110
    '83 XR500R
    '77 '79 XL75
    '73 xr75
    '96 kx100
    '80 JD spitfire x2
    '88 terrapro
    2 JD gators
    springville, PA
    6,185
    Ok JB weld the little f~~~er and drill a hole in the center of the plug itself. Tap it and put a bolt in it. Whenever you want to drain it take out the new bolt you put in.
    Did this on my one SX.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    Heli-coil is the best. But I have tapped it with a 1/4 inch pipe tap and put in a 1/4 inch magnetic pipe plug.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    dblshockpower is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    north woods
    264
    Just seal the damn thing up and use an "Oil Boy" to extract the old engine oil....pretend it's a marine motor.
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    wrap a small amount of sewing thread around the bolt before inserting, should get a couple thousand more miles out of it
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Quote Originally Posted by mymint87
    Not sure I understand this, please elaborate.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Jul 2003
    Limerick Maine
    91
    heli-coil is the beat approche or a expandable rubber plug,but rubber might get soft and come loose. if you do the heli-coil,make sure you pour some clean oil thruogh the engine (after tapping the hole) to rinse out any metal shavings
    PUT SOMETHING HOT BETWEEN YOUR LEGS(350 X)
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    Quote Originally Posted by ANTI-QUAD
    Or put a lot of grease on the tap, that holds the shavings.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    hey, most car parts places have an expanding replacement rubber plug, just make sure you don't loose the tool that comes with it.
    one cylinder is not enough!!
    Jun 2004
    IL
    67
    when we got it, it had a rubber plug in it but i had to destory it to get it out. we'll probably try to retap it or heil-coil it. might be a while before we get to it though.
    '04 TRX450R
    '97 trx300 4x4
    '93 trx300 4x4
    '08 700 grizzly 4x4
    '87 trx250x
    '85 atc250sx
    '85 Tecate x2
    '85 '83 '79 atc70
    '85 atc200s
    '85 atc110
    '83 XR500R
    '77 '79 XL75
    '73 xr75
    '96 kx100
    '80 JD spitfire x2
    '88 terrapro
    2 JD gators
    Jan 2005
    Spruce Head Island, Maine
    893
    tap and die and find a new bolt to fit it..
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Jul 2003
    Limerick Maine
    91
    Quote Originally Posted by oddball3
    thats a good idea too..just goes to show,,,,your never too old to learn something new.....anything it takes to keep that junk out of the case
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    Please don`t quote me on this but "[*]I was told[/*]" that the tool used to tap for a helicoil will not go into the case far enough to cut the threads properly. It hits something inside. That was in reference to the 85-6 Big Red. That means you would have to split the cases.
