Results 1 to 12 of 12
Thread: ported the exaust port, got alot of power. airfooler 'rs check this
    arizona
    550
    this weekend i anticipated going for some riding with a few blasters, and i wanted to make sure i had the upper hand. after talking to a knowlegeable guy at a cycle shop, i decided to try and port my own motor.
    i only did the exaust port, but it tured out great. i had a TON of black ash build up on the flange and port. after i sanded all of that off, i grabbed my rotory tool and started working. i opened up the port just a tiny bit, then polished it clean. after i was done, i had a shot glass sized ammount of ash junk that was in the cylendar.
    after that, i took it out. the mid range has way more kick than normal, and it seems to run alot cleaner on the whole range.
    any of you guys tried this? all that build up could be robbing power, im glad i did it.
    Anaheim
    1,270
    yes... i have before... i put a 85R exhasut flange on a air fooler as it is larger then the stock one... i had to have the exhast pipe opened up for it to fit... but while i was in the cylinder i did clean out the junk... and opened up the port 2mm.
    adam
    it does open it up but really you can only flow as much as you can fit in the largest hole... what you did when you opened up your exhaust port was advance the timing
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Aug 2005
    HI
    1,575
    could you all explain this to me? I want to start portin the R
    Rest in peace Rex Carlson
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    could i just use a dremel and shave the exhaust port a lil, and smooth it out and slap my exhaust back on?
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    springville, PA
    6,185
    go right ahead but we have 4 strokes so even if you did it right you would need to get bigger valves. If you just do the spot where the exhaust hooks on, the most you are doing is cleaning it.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    arizona
    550
    Quote Originally Posted by firefirefire90
    no problem. fyi guys, this isnt for four strokes.
    i started out taking off all of the exaust components. pipe, flange, etc. i took a wire brush on a drill and cleaned out all of the built up ash from the pre-mix. there was easily a mm of the gunk on the port and flange. i cleaned that off, then pulled out my dremel. with a small metal bit i gently widened up the port and flange, just a little bit.
    i talked to a guy about doing something a little more agressive, and he told me depending on the way you angle the transfer ports and exhaust, you can make up to 20% more power. thats about 6 hp for me if i went that route.
    in short, i cleaned and widened the port and flange. alot of crap gets built up in there. i took some material off of the port sides, but not very much off of the top and bottom because that effects the powerband, and i didnt want to risk doing something stupid.
    lastly i took a wire wheel and buffing wheel onto the port, and flange until they were nice, clean, and shiney. worked great for me.
    Feb 2005
    Oregon
    772
    Be carefull doing up the exhaust port for who ever tries this, if you go to far all you will have is top end power, or you may have a junk jug. So be careful that you dont take too much materisl off.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Fresno Ca
    2,695
    I would NOT recommend trying things like this on a 2 stroke. With the pingers theres some vital things there that make your bike run properly. You can EASELY turn a good running bike into junk if you something improperly.
    arizona
    550
    i didnt take barely any metal off. i was just making the point that the black deposits on the exhaust port were holding back power.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    What the %$%%
    Quote Originally Posted by RideRed250R
    adam
    Advance the timing in a 2 stroke ....thats just silly
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by edog
    Im not quite sure if your being sarcastic or if your being serious ?
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Newfoundland
    5,280
    Who knows with edog.
    Port work on a two stroke is something where you "need" to know what your at. Reshaping the intake and exhaust ports changes where power is made in the power band, you could lose power or just plain ruin the cylinder. Best leave it to someone who knows their stuff. Making sure the exhaust port is free of carbon was a good idea however, I'm sure you freed up some good hp.
