View Poll Results: 250es or 250sx
Voters
93. You may not vote on this poll
  • 250sx
    8 8.60%
  • 350x
    12 12.90%
  • 250r
    17 18.28%
  • mikuni
    4 4.30%
  • keihin
    9 9.68%
  • A 2003 Yamaha Blaster
    4 4.30%
  • A 2003 Honda 300EX
    7 7.53%
  • 0-100
    3 3.23%
  • 101-150
    7 7.53%
  • 151-200
    0 0%
  • 201-250
    1 1.08%
  • 225DX
    7 7.53%
  • Klt200
    1 1.08%
  • 250es
    0 0%
  • 250sx
    2 2.15%
  • 250es
    3 3.23%
  • 250sx
    8 8.60%
Results 1 to 8 of 8
Thread: difference between 250es and sx?
    i was just wondering what are the differences between the two and which you think is better.
    Dec 2002
    Kansas
    2,387
    I HATE TO DO THIS BUT IF I DON'T SOMEONE ELSE WILL. ITS THE LETTERS LMAO JOSH
    Quote Originally Posted by smokinwrench
    or not. the 250es is a utility trike, 250sx isn't a sport, but it's got better suspension, lighter, and smaller tires. 250es comes with racks and can tow ALOT (250sx can tow also though) and bigger tires, making it a good hunting or yard work trike.
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    SX has racks too...had some on my 85.(rear only) Pretty quick 4 stroke 250cc though. Suspension was smooth....but yeah its lighter,faster,its more sporty,but it can do the job of a es....
    als250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Well, here's what I know: ES=utility/SX=sport utility, ES=25x12x9 tires/SX=22x11x8, ES=3.2 gal. tank/SX=2.6 ES= hi-lo range trans./SX=not(but 1st gear is so low,don't know why you'd need lower???)
    Both have elec. start,reverse,headlight/taillight,12 volt elec. system,frt. & rear racks. SX is lighter & better suspension (still not great,but I'm working on that on mine!) hence SPORT UTILITY. Guess it all depends on your needs, but for work & play it's " SX " all the way !!!!
    Al
    p.s. gotta leave ya with a pic of mine (not quite all original)
    TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
    '86 350x (latest addition)
    '85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
    '85 250sx(supertrap exhaust,chrome rims)
    '87 200x(restored)-'85 200x-'84 200x
    Feb 2003
    64
    250 Es
    200 ES may have had a high and low range but I dont think any 250ES did.
    They all had the super-low + 4 and Reverse transmission
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: 250 Es
    Quote Originally Posted by Ivan T
    Ivan T, You are correct!! The 250es's here are the same way ( No Hi/Lo ). Only the 200cc Model Big Reds had Hi/Lo .
    The 250es and the 250sx are basically the same motor.
    Howdy
    oops......my bad!! :oops: Thanks for setting the record straight guys!!
    Al
