Results 1 to 15 of 69
Thread: LASt Thread for awhile
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    Talking LASt Thread for awhile
    OK guys this weekend im dad is getting a timing light to check this baby out ill get back to you about the condition but were sure its the timing if i get this thing running soon i will finally feel like one of your cool people....... freakin ridin!
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    there is one think im confused still about how do oyu put it back into timing?
    Jan 2005
    RI
    2,530
    buy a manual and youll have it running in no time...and if you already have a manual, read the manual and you will have it running in no time.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    arizona
    550
    if i lived within 200miles of you id probably drive over and fix the damn thing. but i cant. im almost positive from what youve described its not timing. it would only cost about 60$ just to have a shop find out whats wrong, and then you could go from there.
    good luck though.
    Oct 2005
    Pennsylvania
    863
    If youre using a timing light------USE THE "F" --F is for ignition--T is for valves
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by Unclediezel
    I wonder how well a timing light will work, you need to have the trike running to use it .
    If the timing is off, then the cam chain is off a tooth or more, the only other option is that something is broken.
    BUY A MANUAL!!!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Nov 2002
    Kirkville, NY
    3,831
    Diezel your have to be one of the most patient people on here.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Brandon, Manitoba
    2,209
    Quote Originally Posted by thefox
    I will have to agree with you on that, How many times have you told him the same thing OVER AND OVER AND OVER again
    WHY WONT YOU TAKE YOUR FLYWHEEL COVER OFF AND CHECK TO SEE IF YOUR WOODRUFF KEY ISNT SHEARED!!!
    For the love of god!!!!
    Sorry for yelling but that is VEEEEERY simple to do.
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by Yamahauler
    Exactly!, theres been a load of helpful replies in other posts of guys telling you how you can find out whats wrong but you havent listened.
    When my Z refused to start and unclediezel suggested checking the flywheel key, it took all of maybe 10 minits to check it................ IN THE DARK! so get up and of the computer and go check it, if not foryourself but just to give our patient yamaha doctor some relief
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Oct 2005
    Pennsylvania
    863
    Thanx Guys--I'm Flattered
    Brandon, Manitoba
    2,209
    Was it neccessary to make another thread YTM?
    Wasn't there enough room in one of the other 5 threads you've made about this rather simple problem?
    Anyway, good luck with your endevours
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    OK guys im sorry just tell me what to do now... i took off the pull starter and the timing window screw to se the T and F now what?? besides take it to a mechanic lol sorry for being a dumb ass.
    Mar 2004
    Eastvale, CA
    630
    Quote Originally Posted by YTM200BOY
    Don't be sorry, it sounds like you can't help it! BUY A MANUAL!!!
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    Ok guys i took all of your info and tried it all.. I took off the cover on the left side of the engine that shows the timing chain and yes i think the timing is excellent! it has a mark and its on the top and it lined up with the t in the timing window so i guess its not timing? also i tried starting fluid in the caRB NO GO BUT it back fired 3 times i dont really understand this woodruff key thing you guys are talking about i took the pull start cover off and i see a big bolt in the center do i have to take that bolt off?
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    the electric is all redone so thats not the case
