Results 1 to 10 of 10
Thread: New carb installed T3 *General Jetting Help Needed*
    Newfoundland
    5,280
    Ordered a special set Mikuni TMX from Sudco not long ago and finially got it installed on my 85 T3. It rips, really feel the difference in bottom and topend power too.
    The carb came with a 370 main, 3.0 cutaway on the slide, and a 20 pilot, not sure on the needle now (would have to check again). The thing that had me puzzled was the #20 pilot jet. Why so small? I mean the JWR book recommends a 40 pilot with the TM flatslide jettin specs, the stock 34mm carb had a 40 in it so why did they do everything else right but put that tiny pilot in? Any way I warmed her up, took a while with the 0* weather and got her up to operating temp. The 20 seemed lean, she didnt smoke near as much as with the 40 and stock carb, never did a chop though. But after the motor was hot I stuck the 40 pilot in there. Now it isnt as crisp but my piece of mind is back to where it should be. Rides good and doesnt load up. Plug chops to be done when it isnt raining.
    Also installed my 10 dollar cast aluminum wheel spacers on my 84 hubs, pretty wide and really stable while sideways. The old studs were really easy to tap out with a brass and ball peen .
    Pics later the week when the sun shines and the rain stops. Newfoundland b'y...
    Feb 2005
    Oregon
    772
    Sweet, I just picked up a Kehien 34mm Flatslide for mine, I still need to get the correct twist throttle to make it work, but those Mikunis that came on them stock are just wore out, mine had a bent needle, and a couple wore out parts on it. You get any porting done yet?
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Newfoundland
    5,280
    Yah my old carb was worn, choke was fubar too.
    The cylinder is off at CWR to be ported, Corey Sprock recommended them. Should get it Christmas time.
    Sep 2005
    FL
    855
    I got a dumb question. Who made the T3?
    Jan 2005
    Great Bend
    704
    kawasaki tecate a.k.a. T3 A1-1984, A2-1985, B1-1986, B2-1987
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Sep 2005
    FL
    855
    A2 etc. is the model name?
    Newfoundland
    5,280
    Kawasaki KXT 250 A2 Tecate is how it goes I think, unsure of where the A2 goes.
    Newfoundland
    5,280
    Some general jetting questions and stuff for you guys now. Thinking that the #20 pilot jet that was originally there was just fine in the carb. *Has anyone ever burned up a 250 two stroke because the pilot was too small?* I fouled two plugs tonight after the bike was run up to operating temp, never fouled one on the woods ride today but at 1/4 throttle you could hear the bike load up on fuel....Thats with the #40 pilot jet from my stock carb installed. Back to 20 tomorrow morning and plug chops are on my to do list.
    Apr 2003
    Dodge, Nebraska
    168
    This is what I would do if I were trying to find the right pilot jet. This comes from Trinity Racing for a Mikuni carb.
    For the pilot Jet. Start with the one in the carb. You must first locate the air screw on the side of the carb( this is not the large idle adjust screw but the small inset screw). If the screw is to the rear of the slide ( closer to the air filter) it adjusts air. If it is to the front (towards the motor) it adjusts fuel. I will deal with the one that adjusts air since it is the most common. Start by turning the air screw all the way in, then back out 2 turns. Start the bike and keep it running till it warms up. Set the bikes idle screw (the large one) so the bike idles some what. Now turn the air screw clockwise slowly until it's all the way in. If the motor continues to climb all the way till the screw bottoms, the pilot is to lean. The actual result should be it gets to rich and dies. If you have to screw the air screw more then 2 turns out to get a good idle it's to rich. To achieve a good clean idle you should be between 1 to 2 turns out. The opposite of this is true if you are adjusting gas.
    Hope this helps some! Good luck!
    It ain't about the money, or even being #1, you gotta know when it's all over you did the best you could of done! And knowing that it's in you and you never let it out, is worse then blowin' any engine or any wreck you'll ever have!
    _________________________________
    84 Tecate RED with a 310 Big bore!
    84 Tecate Red
    84 Tecate Green, in pieces(was a parts bike, not anymore!! )
    85 TECATE--NICE!
    85 350x needs a little tlc
    86 350x
    86 TRI-Z
    Newfoundland
    5,280
    Installed the #20 today and it runs good. Set the airscrew at 2 turns out and rode it hard all day without a problem. Plug is dark brown.
