Results 1 to 15 of 23
Thread: My Tecate Kicker Is Broken
    Newfoundland
    5,280
    Well the mounting base on my T3 kicker broke off at the pivot just below where the ball in the kicker goes. ( Know where I'm talking about?)
    In any case I've mig welded it several times and even took it to a professional welder and it keep cracking off. Temp solution?
    I've got a replacement on the way from Meat-box whos been awsome with helping.
    James
    springville, PA
    6,185
    Get some locking ajustables. Works for shifter so why not a kicker.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Newfoundland
    5,280
    Quote Originally Posted by 250sxwheeliepop
    lol
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Try what wheeliepop says, it should work.
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    Newfoundland
    5,280
    Kick over a Tecate lately? Those vise grips would come loose first kick. Besides that the frame is in the way. I'll jump start it before I put on pliers....
    Weld a socket on there with a 1/2 drive ratchet.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Cody's Avatar
    Feb 2005
    FLORIDA
    731
    Oh never mind. I didnt know he was talking bout vice grips. LOL! Id never do that.
    springville, PA
    6,185
    Quote Originally Posted by Cody
    lol come on, ya gotta try new things once in a while.
    Nate
    R.I.P HRR
    Nov 2002
    Kirkville, NY
    3,831
    Then what did you think he was talking about?
    Big Green, like you said push start if you want to ride that bad, any quick fix will just lead to a bigger problem, you don't want to strip your kicker splines.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Newfoundland
    5,280
    Got it welded again today. I've mig welded it several times but this guy had the gas setup with his mig, seemed to do the trick. Anyway he said that the part to be welded was hardened steel vs the softer steel bead of weld so it wouldn't hold up. In any case its holding on right now so all I can do is put some faith in it.
    Later guys.
    Newfoundland
    5,280
    Hot new pics! Kicker broke off again lol but I welded it and it hasnt broken off during some hard kick backs from the bike...PICS!!
    Notice how tight the steering is, the fork tubes hit the tank. New seat cover, wheel spacers and new carb too. Snow in some pics, love the little bay of ours in the others. Newfoundland is the hot spot to be, absolutely beautiful spot.
    Jul 2003
    indiana
    892
    Yea, Tecate kickstarters are kind of finicky. Some how mine lost the little ball that is inside the kick start wher it slides onto the piece on the kicker shaft. Know what I'm talking about? Don't know how it happened, It was there when I started riding and after a while of beating on it the kicker started flopping around a bit then it would just do what it wanted! I know for a fact that the ball was in there when I started riding because the kicker locked into place. I think you need to come down to Trike Fest this year. Who knows it could be the only 85 there other than mine!!
    Newfoundland
    5,280
    You know for sure the ball isn't there? Might be seized, mine was until I fixed it. If not then it prollay came out the back where the allen screw and spring are supposed to be.
    Trikefest is a dream lol. Too far to travel with the trike on my budget but definately some day.
    Trike has a date with the pressure washer and a can of Gunk degreaser Saturday after my ride. lol Needs a bath badly.
    Jul 2003
    indiana
    892
    Oh, I know for sure it is gone. Took it apart and was like uh, where did it go?
    Newfoundland
    5,280
    Thats weird dude, theres no space for it to come out.
