Results 1 to 15 of 15
Thread: I think my transmission is goin out.
    Jun 2004
    texas
    70
    I have a 1984 Honda ATC thee wheeler. It usually shifts fine and runs great, But about two days ago i was riding it and i shifted into third gear and it went into neutral. I shift in neutral it goes to first. When i shifted in first again it went all the way to forth gear. Is my transmission going out.
    Dec 2005
    iowa
    16
    your tranny is goin out of your trike and your gear box is set up wrong
    Oct 2005
    Pennsylvania
    863
    Sound like a shift fork problem-- You will have some dissasembly time ahead of you--but first check the obvious nonsense that you can easily see--external linkages --before going further into the unit.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Howdy's Avatar
    Celina, Ohio
    10,079
    I have worked on a lot of 90-110 with simular problems. What normally is the problem is the stopper pawl breaks. The stopper pawl is used to hold the shifting tumbler into a certain possition. If it breaks then it can no longer do this, thus it can jumb from one gear to the next. It's not that hard to check it either. I have attatched a picture showing the stopper pawl ( #1 ).
    There is a slight chance the bolt on the end of the shifting drum has come loose ( #2 ). But it's only a slight chance ( there would be other symptons ).
    Hope this helps
    Howdy
    Edited: Corrected a spelling error.
    Oct 2005
    Pennsylvania
    863
    Wouldnt the "DETENT" feeling be gone? - Technically- Should'nt the "Star" just "Freely" bounce around and thrash itself between gears on engagement?
    Oct 2005
    Pennsylvania
    863
    oops----E-slap For uncle-D
    The detent is gone--Thats why it ends up in errattic positions---But how did the tumbler not trash itself?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Unclediezel
    The tumbler wouldn't trash itself because the shifter arm will ( ever so slightly ) try to hold it into a gear. But it's not enough to sustain it.
    Howdy
    Front royal, va
    2,186
    i have a comlete bottom end for one if you need it
    Jun 2004
    texas
    70
    I have another 70 motor but i dont really know how to work on transmissions, I just put the head, Jug and piston on it and now the transmission is messing up and i daont know how to fix it.Thanks
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by honda110
    To fix your problem you probably wouldn't need to dig deep into the tranny. The part I described is under the right side cover ( clutch cover ). The picture I posted above is for a 90,110,125m. But the 70 motors are simular, but different. It probably is only a 1 - 1 1/2 hour fix for a first timer. And if you can do a topend you shouldn't have much problem fixing this one.
    Howdy
    Nov 2002
    460
    Hey guys,
    listen to Howdy , he is 100% correct on this I too have worked on Hondas for a long time and this is a real common problem with this style engine, like he said either the bolt backed out witch happens or the arm on the spring loaded detenyt lever broke. its a 20 min job flip the bik on its side and pull the clutch side cover , you will have to pull the clutch and 1 gear to access it but very easy. Listen to the old guys we know a few things
    take care
    Mike
    Jun 2004
    texas
    70
    70
    How do i pull the clutch and 1 gear.
    Feb 2006
    Central Florida
    1,090
    drain the oil, drop the clutch cover - you should be able to see the parts they are talking about behind the clutch.
    get a manual if you do not have one. it will help
    quiet people seem intelligent
    florida
    2,328
    hey rally this is over 2 years old LOL
    Feb 2006
    Central Florida
    1,090
    I went back in time just to help honda110 out!
    your right - looks like he figured it out and never came back.
