Results 1 to 10 of 10
Thread: Making a swingarm, have a couple of questions for you guys
    Jul 2003
    indiana
    892
    Ok, I am building a swing arm fro my 85 Tecate and I was wondering what should I use? I know chromoly is increadibly strong and light but what about aluminum? What thickness should I use for either the chromoly or aluminum! Also what grade? I think I need to say what kind of riding I do also, anything from cruising around the house to mx. Anyhelp would be great as I am going to try to work on this here in the next couple of weeks. Thanks
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    If I were you, I'd sweet talk oldschoolin86 for some pointers.
    May 2002
    Southeastern Wisconsin
    3,658
    To be honest I've never looked into aluminum. Sorry. If I was going aluminum tho I'd start by going down to my machinist and seeing how much the piviot and carrier housing was going to cost to get made. That's going to be one of your most expensive parts of this deal.
    Newfoundland
    5,280
    The Tecate carrier is seperate from the swingarm like the Tri-Z so thats not necessary.
    Jul 2003
    indiana
    892
    Yep carrier is seperate, not like those goofy hondas The pivot points that the swingarm bolt goes through is what you are talking about right oldschoolin? That should just be a piece of tubing welded into place correct?
    Newfoundland
    5,280
    90nut, if I had my Champion swingarm money back I'd buy a updated swingarm from osin86. That way I could run some sweet TRX 400EX gear on my T3 like the aftermarket carriers, axles, brakes...
    May 2002
    3,658
    Quote Originally Posted by BigGreenMachine
    I know, I should have worded that different but there's still some carrier parts there that could benifit from proper machine tools IMO.
    Jul 2003
    indiana
    892
    I should be able to machine the parts I need with my buddy's lathe, mill and if it comes down to it his neighbor has a CNC machine he can use. On second thought it is not a bad idea to use the honda rear carrier set up. Oldschoolin' I am going to hit up you web site and take a look around.
    Jul 2003
    indiana
    892
    Only down side I can see with the updated rear carrier is the added cost for the 400ex stuff.
    Newfoundland
    5,280
    I know but I don't think your in a rush, buy a swinger and then piece together the rear end. someone is bound to have a take off rear end on ebay.
