Thread: 350x Front Fork
    NASHVILLE
    514
    350x Front Fork
    Bottom of fork leaking? Does it have to be removed to fix? Wasn't leaking before.
    Current Rides:
    All Red's!
    Jan 2005
    Great Bend
    704
    if its the very bottom of the fork there is a bolt at the bottom that probably needs to be tightened. no more than 15-18lb-ft of torque.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Jun 2003
    South of Rochester, NY
    3,471
    Quote Originally Posted by ATCWRENCH
    It's a 6mm hex head.
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    NASHVILLE
    514
    I was told the bolt and washer can be replaced with out removing the fork. True or Farse? I have new seals but will probably have to order the copper washer for the 6 mm bolt.
    Current Rides:
    All Red's!
    Apr 2002
    s.w. michigan
    6,498
    yep
    Yes you can replace the 6mm bolt with the fork intact. I would recomend to NOT jack up the front to take the pressure off the springs inside. Remove the bolt first.
    You will want to jack it up to put the oil back in that fork leg so as too remove pressure on the springs inside when you remove the fork cap.
    You sure the oil is not coming from the seal ,,,, ? Perhaps raise the fork boot and see if any oil around the seal.
    john
    Minnesota
    784
    The bolts on the rear of the bottom of the forks I believe is to drain the fork oil, there are allen bolts in the very bottom of the forks that hold the dampening rods I belive. Before doing any work on a fork bleed all air out of the air valve on top. I did not do this and removed the drain bolt and it was under great pressure, got my face/eyes full of ATF.
