Thread: forks
    Dec 2005
    cleveland,Ohio
    11
    forks
    What do progressive forks springs mean. Thanks
    Rittman, Ohio
    6,276
    It means the spring rate changes "progressivley" as you go through the length of the spring. In simple terms, the coils are closer together at end of the spring than the other. The benefits are that they are lighter than a single rate spring when fully extended, but stiffer than a single rate spring when they are compressed so you end up with a smoother ride on the light bumpy side, and less bottoming out on full compression jumps.
    Baltimore, MD
    6,088
    It's also a brand name of the fork springs and shock absorbers.
    Jun 2003
    South of Rochester, NY
    3,471
    Quote Originally Posted by Vealmonkey
    Progressive Suspension is the name of the company.
    Progressive Rate Fork Springs is what they sell.... as what tim said. The "k" value of the spring changes as it is compressed. The front ones I have on both 350X's and my 250R. I have a rear spring from Progressive Suspension on my 250R... it's just plain stiff! (Baja Magnum spring.... old school!)
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Dec 2005
    cleveland,Ohio
    11
    Thank's guys, Iknew it was more than a company name.Those are what I am looking for. Time to buy some springs.
    Newfoundland
    5,280
    Have them in my Tecate as well, very nice for rough rides and surprisingly smooth in the slow trails.
