how do you adjust the fuel level on a stock 86 200x carb. my bike hesitates from 1/4 to 1/2 trottle and i think the fuel level is too low but the float is plastic so i cant bend the tab to rase the fuel level. is there any way to do it?
pic
Nice work John! :clap
Joel Morris
Purdue University Graduate Student
Mechanical Engineering Technology
1985 ATC70
web.ics.purdue.edu/~jsmorris
thanks joel ! i am getting a little better at this stuff,,, not much but improving.
it seems i had the same problem as redrider200x at one time on a trike and found the boot between the carb and head was sucking air due to a big ole crack + it sure gave fits untill i figured it out.
john
Floats wont cause hesitation. If they are too high, it will piss gas out the overflow. If they are too low, it will die when your getting on it, and recover 5 seconds or so later as more full feeds back into the bowl. Floats are not a critical adjutment. They work exactly like the float in your toilet. They simply shut off flow when the bowl is full. The idea is to keep the bowl full without overflowing, in both cases. They have nothing to do with throttle response, or how fast the water flows through the toilet when you flush it.
its not a slight hesitation but more of a sputter like its about to die, it sputters real bad when im riding a whelle or going over whoops and it takes a few seconds to recover. should of explain better the first time thanks for the pic, i will try to see if that will fix it
are you sure the right carbs on there. The 200x has adjustable float,as in John's pic (good job John!)but my 250sx has all plastic float (non-adjustable, just replace).
Al
TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
'86 350x (latest addition)
'85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
'85 250sx(supertrap exhaust,chrome rims)
'87 200x(restored)-'85 200x-'84 200x
i got a plastic float
rr200x- what year is your x? According to John's diagram,which I'm assuming is for '86-('87?), step #4 says there's a metal tab on the float arm. If yours is all plastic like my sx's,no adjustment.
its an 86. i was hoping someone knew how to rig it to raise the fuel level
