Thread: spline count on axle
    Nov 2005
    New Jersey
    659
    Anybody know what the spline count is on a Durablue HD axle for my 350x by chance?doesnt list it in the catalog and Im trying to buy hubs for it.
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    Mar 2004
    North Central Ohio!!
    2,712
    Not sure, but the only hubs I know that will fit are 250R hubs. They're good deals on billet hubs on ebay if you watch.
    Nov 2005
    New Jersey
    659
    250r hubs huh-I wish they would specify that when purchasing, I assumed the stock hubs would fit onto the the axle when installed, you saying just the 250r ones will work correct?
    Sep 2003
    Elizabethtown PA
    1,581
    350x and atc/trx 250r hubs are identical. they are both 26 splines. just reuse your old hubs on the new axle.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Nov 2005
    New Jersey
    659
    My old hubs are both cracked if you can believe it-unreal huh?I was toying with the idea of the billet hubs, they are pretty costly but the look is very nice, I may go the route of OEM and send them to my powdercoater, that may be the way to go, but I'll research the billet hubs as well over the internet to see if I can locate a deal somewhere-you just never know.26 SPLINE IS STANDARD HUH, THANKS MUCH FOR THE INFO, YOU HAVE BEEN A GREAT HELP!!!
    Sep 2003
    Elizabethtown PA
    1,581
    no problem
    the factory ones go cheap on ebay. $30 0r $40 for nice ones. just search under honda trx 250r. theres usually billet ones on there also..
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
