Results 1 to 8 of 8
Thread: atc guys argueing
    atc86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bangahore, mi
    306
    atc guys argueing
    couple of fellow atcers arguing about 400ex hp vs. 350x hp on another website. wanted to get your expertise on this issue as i am also wondering.
    I want a race honda with reverse.
    Aug 2002
    332
    Bone stock 1985 350X (mine) is 24 bmhp (brake mean horse power)
    Bone stock 2002 400EX (Jordans) is 29 bmhp
    These numbers are straight from the service manuals.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    Apr 2002
    s.w. michigan
    6,498
    words andl etters
    hey joel, can you explain to me in a nut shell so to speak,,, what is b.m.h..p compared to just plain ole horse power ?
    (it ain't the horsepower that counts,,, it's the tourqe !)
    john
    Aug 2002
    332
    THey are actually the same thing. When horsepower is measured on a dyno it can be either directly measured or calculated from measured torque. Usually, it will be measured for the low torque engines; like a 2-stroke. However, the high torque engines like 4-strokes have HP numbers calculated from the torque and RPM, and the result from the average brake power required for resistance to torque, or brake mean effective horsepower, is BMHP.
    Joel Morris
    1985 ATC70
    Apr 2002
    s.w. michigan
    6,498
    ohhh, i see.
    okay ! i had seen the bmhp before about my 350x and thought it was weird that they didn't just give it in english. but now know it is another way of basically rating the same thing. thanks joel.
    john
    Feb 2003
    64
    I believe you but,
    24 bhp seems a bit weak for a 350X
    The TRX350 of 1986 had 25.5 bhp and the 281cc engine in the TRX300 Big Red 1988 has 21.3bhp
    Doesnt seem like they had made any effort to tune the engine for the X spec bike.
    NE. Ohio
    484
    My buddies have the same set (350x 400ex) They've raced a hundred times and they cant seem to come up with a clear-cut winner. Whoever gets the holeshot wins.
    Rittman, Ohio
    6,276
    Drag racing has little to do with horsepower unless all other factors are the same. Kind of like the "which weighs more, ton of feathers or a ton of lead" question. Which motor has more horsepower, a 350 on a 300lb trike chassis, or a 350 on a 600lb utility chassis?
