Thread: Correct way to rebuild bottom end...
    Jan 2005
    RI
    2,530
    I have a bottom end of a 350x motor that will stop when i turn it over by the flywheel. I would like to fix this motor up nice and then throw an aftermarket piston and maybe a cam/valves in to to make a little more power.
    What could cause the flywheel to suddenly stop when i try to rotate it over? It doesnt complete one full stroke.
    Also, what should be rebuilt/replaced when redoing the bottom end? I have never split cases before, but it seems really fun to try, and itll be worth it when finished.
    So if you guys who have had experience doing this before could please let me know what parts I would probably need so I can order some of the stuff before i dig in.
    I have the honda service manual but i dont know how much of a help that would be.
    Thanks,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2004
    Waterloo IL
    2,701
    I would guess you might have a stuck valve causing the motor not to turn over and in my opinion I wouldn't split the bottom end if there is nothing wrong with it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Pa.'s Highest City
    8,058
    Your not going to know exactly whats wrong until you open it up. If your going to do this yourself and have never done it before be sure to have a manual and a camera to take shots as you disassemble the cases. I would look behind the flywheel for a broken key or anything else external before I dive in. It is no fun by anymeans if you don't know what your doing.
    Jan 2005
    RI
    2,530
    there is no cylinder head / cover on the motor, just a cylinder/piston so it cant be the valves.
    I thought the cam chain fell into the bottom of the case but i looked and looked and theres nothing there...any more ideas?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Aug 2004
    Ab Canada
    4,368
    Chunk of piston in bottem of the crank case's perhaps? Anyways, if your rebuilding the bottem end, depending on what the crank bearings look like, i would replace them, also 350x's are known for weak connecting rods so i would replace that with a heavy duty one.
    1985 Tri-Z-
    Could be anything at all, unknown until you dive in. 4 stroke bottom ends are real real tough and unless they ran real low on oil usually do not require alot of attention. Of course the clutch etc. wear out and if abused bad enough, the gear train could have some problems. Truly, I don't think I have ever even changed the main bearings in a four stroke, they are in constant contact with the oil and never seem to wear out. If they have been beat that bad or ran out of oil they are not worth repairing and better used for parts. You could have a simple easy problem but won't know until you split it, which by the way is usually when people tend to ruin alot of good parts from inexperience and some screwdrivers in the wrong places...
