Page 4 of 9 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 135
Thread: Possible 87 250R found..(UPDATED) 7.31.06
  1. #46
    Jun 2006
    Ohio
    57
    I just saw this thread for the first time since I'm new here. Hopefully I can give a little useful info. I worked at Andrews Honda in Salem, Ohio from March of 1987 to July of 1987. While I was there, we had 2 '86 250R's and 1 '85 250R on the showroom floor. They were available for sale at that time, so the order to destroy them must have come down later than everyone thinks. This should make the possibility of an '87 exsistence more likely.
    "Everything's a good idea when you're drinkin'"
    "Without rules, we'd all be livin' in trees, flingin' our crap at each other" - a very wise man
    2003 Lonestar 250R
    2001 Lonestar 250R
    1986 TRX250R restored to new
    1986 TRX250R still in pieces
    2007 TRX450R
    2004 TRX450R
    1999 CR250
    1999 CR500
    1996 CR250
    and many more
    GNCC Vet class
    #102 (WTF)
  2. #47
    Jun 2006
    Willow, Alaska
    1,337
    Every little bit of info helps! I personally dont think this ones an '87, but Im sure somebody somewheres got one of the few lucky trikes to make it past chopping stashed in a barn somewhere and doesnt know that its rare.
    -Nick
  3. #48
    wales..uk
    1,318
    Well i found out it is a 86 bike but the guy bought the plastics and decals in 2000 ....here's some more pics......
    Need Honda ATC TRX NOS restoration parts??? or come check out our ATC brochure site
    www.offroadvintage.com
  4. #49
    Jun 2004
    Pyeongtaek, South Korea
    474
    I wonder where the radiator shrouds came from, because they are much higher quality than Maier. Look at the edges of the air holes. They are recessed and very crisp like original Honda parts, whereas Maier's are fairly soft and rounded around the openings. The bolt bosses are much larger on the Maier shrouds, too. The white shrouds are definitely injection molded.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
  5. #50
    Jun 2004
    474
    I just noticed another thing. The decal has a white background. Why would you put a decal with a white background on a white shroud? You wouldn't because it makes no sense. Unless they were made by Harlan or someone with the same equipment, I would speculate that they might be genuine Honda. Not even the cheap layered repro decals would have a white background. Other than exact reproduction type decals, only real ones from Honda would have the white background, just like there are red backgrounds for use with red plastic. This is getting interesting.
  6. #51
    wales..uk
    1,318
    Quote Originally Posted by 69HemiGTX
    All honda Oem decals have a color background??? check out any 86R decals??they got a red background....
  7. #52
    May 2003
    Houston, Texas
    2,409
    Hmmmm...that is interesting about the background
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
  8. #53
    May 2002
    Texas
    2,670
    Am I seeing this correct??? It may be an 86 250r, but that looks like factory plastic. In white? Did he order 87 flavor plastics & decals back in 2000 and actually got them?
    If you look at the 3rd pic, up under the rear fender, it looks like you can see the boss in the plastic that the "forward" rear fender support hooks into. I can't remember for sure, but it isn't it true that Maier plastic does not have the hook bosses????
    MIGHT be an indication that the rear fender is indeed a factory Honda part.
    The shrouds & decals sure look it to me. The white matches perfectly from the decal to the shroud, just like the OEM red ones.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
  9. #54
    May 2003
    Houston, Texas
    2,409
    Also look at the cut out of the graphic around the wing...exactly perfect.
    I don't have reproduction shroud graphics for my R but tell me are they usually cut just right like these?
    Also that R is exactly like the '87 pic in the famous '87's Brochure'
    Dirtbikes:
    1988 Yamaha DT
  10. #55
    May 2003
    Houston, Texas
    2,409
    One more thing....that lead me to believe that these are in fact OEM decals.
    Notice where the '2' and the '5' are multicolored and the red and blue blend.
    There is a slight overlay that actually makes it darker...like a purple. All the OEM decals on my '86 R have that exact type of 'blend'.
    Thats one thing that Harlan's decals don't have. So these look like the real deal to me.
    Has anyone tried to order some?
    Dirtbikes:
    1988 Yamaha DT
  11. #56
    May 2003
    Houston, Texas
    2,409
    Someone needs to get a close up of the rear fender to see if there are warning labels molded in there.
    Ask the owner and see if he can get a close up. Or if its for sale...someone buy the dang thing!!
    Dirtbikes:
    1988 Yamaha DT
  12. #57
    wales..uk
    1,318
    Yes i'm 100% sure these are OEM fenders and decals only reason i haven't posted the pics earlier is i'm still tring to buy this bike or get hold of some plastics...but not had that much luck yet...the guy did infact find these parts on the self of a dealer in Japan....this was back in 2000 but sure there must be more out there...i've got the 87R part numbers in a parts manual.....I sure there's white plastics out there just got to find them
    only find one more pic.....
    Jez help me out dude????you got them all
  13. #58
    Dec 2002
    374
    here is another japanese web page about 250r's...doesnt look like this guy knows anything about an 87 either http://www11.ocn.ne.jp/~kaz-zx11/ATC250R.html
  14. #59
    May 2003
    Houston, Texas
    2,409
    Wow Pete....this is amazing news!!
    I think the world just stopped for a second...yes someone buy up all that '87 stuff before they throw it out!!
    Dirtbikes:
    1988 Yamaha DT
  15. #60
    May 2002
    Texas
    2,670
    That is awesome, because there has definitely been an 87 seat on ebay. I had noticed it on ebay and I think Jez bought it.
    Now there's proof of 87 flavor FACTORY fenders and decals in white! Man, if that trike just had the white head light plastic.
    Anyone have any info on the rear fender "ATC250R" decal that's on the very back? Is the one on the bike actually 86? What's the difference between 86 & 87 on that decal except it should have a white background instead of red?
    Exciting!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
