Results 1 to 8 of 8
Thread: bigger carb for 110/125?
    zoomerman's Avatar
    zoomerman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ontario, Canada
    351
    okay i am looking for bigger carb that will fit on a 90/110/125 (they are the same intake i think) anyways i kno there must be something that will fit on these machines i would like a 22mm or bigger i think. i am just looking for much options right now.
    thanks,
    Evan
    1985 suzuki alt 185
    1985 honda atc 250sx
    1985 honda atc 200m (all apart)
    1984 honda atc 200es
    1984 honda atc 200x- need motor, plastics, axle, exhaust.
    1984 honda atc 125m- times 2
    1985 honda atc 200m all apart
    1983 honda atc 200e times 2
    1983 honda atc 250r-times 2
    1983 honda atc 200 4 parts
    1983 honda atc 110 times 3
    1979 honda atc 110 smokey
    1978 honda atc 90- restored
    Have lots of extra parts, if interested email at e_mcy@hotmail.com
    springville, PA
    6,185
    the 90/11/125 are all bolt on to the intake manifold right? if so I believe the 200es big red has a 24mm carb that bolts on the same way. I'm not sure if it will fit but its an idea.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    zoomerman's Avatar
    Ontario, Canada
    351
    i have no idea about the 200es carb i have never seen one. could someone verify this please?
    1985 suzuki alt 185
    springville, PA
    6,185
    yeah the 200es bolts on too but I'm not sure if it will bolt on to yours
    Nate
    R.I.P HRR
    zoomerman's Avatar
    Ontario, Canada
    351
    ok for hose who don't kno what it looks like this is how it bolts up. the head is off because i'm boring it out... anyone know where i can get sprockets also"
    1985 suzuki alt 185
    zoomerman's Avatar
    Ontario, Canada
    351
    will a 200m carb bolt right up? and what about a dirt bike or atv carb?
    1985 suzuki alt 185
    May 2005
    Dorset United Kingdom
    1,408
    Any gains you might get from a larger carb will not happen unless you get a bigger inlet manifold thats a better shape. And even then the size of the intake port will restrict it. If you were going to go full out on it you could find another inlet manifold to match the carb and have the port enlarged, but the question is..... why?
    will
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    zoomerman's Avatar
    Ontario, Canada
    351
    i will buy the inlet manifold too the reason i'm doing this is i'm puttung alot of money into this machine to get it going and looking nice but a piston rings got caught and it caused the piston to rub against the cyllender so i'm getting it bored out .25 and i figuered y not make it a mini dragster lol so thats why i'm looking for a bigger carb i have a K&N and i'm getting a pipe for it and maybe a rear sprocket too
    1985 suzuki alt 185
