Results 1 to 15 of 22
Thread: 125 M.. Someone please give me some ideas
    Jul 2004
    Mud hill. close to water !
    3,658
    Ok... here we go.
    Yes.. i have the service manuals for the 185/200 and the 250 ES/SX.. i don't YET have the manual for the 125. Bid on a few.. got outbid.. i will get one. ps: if anyone has one for sale !!!! "wink "
    I have an 84 125M that has bottom end issues.
    The shift lever goes up.. down.. and returns to the middle position.. so the spring is not gone.. the sub tranny lever will go from high to low.. but she's stuck in Neutral no matter what i do.
    Wich side do i dig into first.
    1- Sub Tranny
    2- Left side cas
    3- Right side case
    I'd really like to not have to remove the pipe as she's pretty rusty on the head section.
    Where shoud i start ?
    Currently :
    zoomerman's Avatar
    zoomerman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ontario, Canada
    351
    i would start with the sub tranny
    1985 suzuki alt 185
    1985 honda atc 250sx
    1985 honda atc 200m (all apart)
    1984 honda atc 200es
    1984 honda atc 200x- need motor, plastics, axle, exhaust.
    1984 honda atc 125m- times 2
    1985 honda atc 200m all apart
    1983 honda atc 200e times 2
    1983 honda atc 250r-times 2
    1983 honda atc 200 4 parts
    1983 honda atc 110 times 3
    1979 honda atc 110 smokey
    1978 honda atc 90- restored
    Have lots of extra parts, if interested email at e_mcy@hotmail.com
    Jul 2004
    3,658
    Aight.. as good as any.
    The lever does not " click " or try to engage any gears what so ever.
    I wish i knew the history of the machine.. unfortunately i do not.
    I've noticed oil on the bottom case.. and what looks like 2 possible drain screws for the oil .. one the of the 4 footpeg bolts that mount to the case is snapped in the case.. will have to drill and tap. ( i plan to have everyone on this thing !! lol instead of my SX ! )
    Currently :
    zoomerman's Avatar
    Ontario, Canada
    351
    thats what it sounds like it it doesn't click at all.
    1985 suzuki alt 185
    Jul 2004
    3,658
    I am refering to the foot shifter.. not the high/lo lever by the way !!!
    Currently :
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    I got a 125m og my own, and if you do not have it in high or low completely it will not shift. With my subtran I shifted into high, pushed some snow. Then popped back into high and it wouldnt shift. So I hit the lever with a into high, gave it some good hits, started it again and she went into first and second...ect so just jam it into high as hard as you can.
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    Jul 2004
    3,658
    Quote Originally Posted by 85hondaatc125m
    Went out and tried it.. no go.
    Anyone else ???
    Currently :
    zoomerman's Avatar
    Ontario, Canada
    351
    i would just take the sub tranny off and check it all out i was drving my 125m and the high gear broke (which i still don't have) and i thought the chain fell off but it didn't i clicked it in low and off i went i think something is broken in there can you fell and friction at all when you move it bak and fourth?
    1985 suzuki alt 185
    you tried adjusting the clutch with the bolt on the cover?
    1983 Honda 110
    1967 Mustang
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by bigredhead
    Ok... here we go.
    1- Sub Tranny
    2- Left side cas
    3- Right side case
    What this sounds like to me is a fairly easy fix. To me it sounds like one of these 2 things:
    #1 The bolt came loose out of the end of the shifting tumbler. To check this you will need to remove the right side case ( clutch cover ). You should be able to inspect the bolt without removing anything else. It's #2 in the picture below. This one is my pick for the most likely problem. I have seen quite a few of these.
    OR
    #2 The shifting arm may have broke up by the shifting tumbler or the spring ( that lifts the shifter engaging arm ) might have broke or come off. This should also be able to be inspect it with only removing the right side case / cover. If you look at the picture below you can see the arm that comes up from the shifter shaft. You can see ( barely ) the arm that comes off it and goes towards the shifter tumbler. Sometimes these break right in the middle.
    If you inspect these and find one of them bad let us know. We will give you further inspructions on fixing it.
    Howdy
    Jul 2004
    3,658
    Awsome.
    I'll be diving in tonight or tomorrow at the latest, and i'll let you all know !
    Thanks !
    Currently :
    Indiana
    115
    Quote Originally Posted by 42F67N
    thats exactly what I was thinkin.My neigbors 110 had the same problem, there was something broke, but adjusting the clutch still made it shift right. I can't remember exactly what broke, but it was on the right side.
    My 84 125m had all kinda shifting problem once i adjusted that clutch nut it was perfect.
    1983 Honda 110
    1967 Mustang
    Jul 2004
    3,658
    Well... i was at it until 4:30 am but i found the problem !
    Most of the case cover bolts came out wihtout a fight.. 2 of them however.
    The bottom philips bolt under the exhaust was mangled to hell and then some.. i had to remove the pipe.. surprisingly it came off no problems..
    Then i spent an hour and a half with a dremel.. easyouts.. files.. cutting disks, vicegrips, plyers.. torches. x amount of lubricants.. everything i could find in the garage... ...
    VERY long story short.. i got the damn thing off and found this inside :
    Currently :
    Howdy's Avatar
    Celina, Ohio
    10,079
    hmm, my #2 that I posted before was dead on target!! At any rate I am glad you found the problem! Need any parts to fix it?
    Howdy
