Thread: Finally got the 350X (Saturday), broke an intake valve Sunday!
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    For those who remember me (leaving my old sig for a bit to jog memories) I finally bought a 350X. I went to look at it with my friend, hoping I wouldn't actually buy it but I did. '85, high comp Wiesco (they said its 11:1 but they don't seem to make an 11:1?), stupid Cobra noise maker, everything else stock as far as I know. I paid $750 knowing it was leaking some oil from the left side cover and the gas tank is seeping due to rust. However, fork seals seem good, the decompression cable works!, and it has a new OEM style front tire (though the rears are all but bald Holeshot rip-offs). I guess I did fairly though I didn't look it over like I should have. Let me know what you think of the deal.
    So yesterday we went riding (friend has a 250R) and after about an hour everything was great and it just died. We pulled it/pushed (mostly pushed) it with the R up to the house through the snow (a spectacle in itself) and found that that left intake valve stem broke, causing the valve not to pull itself but up into the head, the piston doing the job for it. Hence the piston is a bit "polished" at 2 spots opposite the reliefs, but certainly usable. There's no serious metal anywhere, so we're hoping to hone it, ring it, get the head up to speed, and have it back together.
    I probably could have avoided this had I changed the oil before riding, but having not ridden in a year I was a little impatient. The oil smells like kerosene and was a little low. Fortunately I'm not upset because at the end of the day I still have a 350X.
    There's my semi-organized thoughts, feel free to shoot back at me with w/e. Great to be back!
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    old honda dealr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    texas
    215
    Kind of a bitter sweet story. But I like the outcome. You now have a 350x
    Bikes I currently own.
    1985 250sx with Hondaline Tank Cover
    1986 Tecate with 1998 KX250 motor Eric Gorr 285 big bore kit.
    1985 200x sold
    1986 200X in restoration
    1981 110 stock
    1987 Big Red
    1985 250r doing total frame off rebuild.
    1985 350x with 86 fenders
    1985 350x in excellent original shape.
    1987 atc125 Near perfect.
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    I remember you just fine- you used to have a 250 with the 350 headlights, the plastic tank and the fork guards and an exhaust rigged up with plumbing for a while if i remember right (wasnt it a white brothers e-series?). Its nice to see that you got yourself a 350. I know how it is to get a 350 and F it up within the first week. Beleive me, I've done it twice. Its cool to see you back though. Have fun with that 350.
    The below sentence is TRUE.
    The above sentence is FALSE
    Halifax, PA
    400
    Yep that's me...
    Halifax, PA
    400
    OK. The head is at the shop to have a new valve guide pressed in. My question to all of you is what you would recommend for the head. I intend to put an aftermarket cam (nothing too crazy, but i like to rev) in eventually (if not now) so I was figuring it would be a good idea to install new valves, springs, and retainers, then have a 3 angle job done. I'm not sure what would be the best parts to use though, or if I'm missing anything or overkilling. Please let me know your thoughts.
    Halifax, PA
    400
    bump
    bump some more because my post is too short...
