Results 1 to 13 of 13
Thread: tecate with kx 500 engine?
    Jan 2005
    Eastern PA
    95
    How hard would it be to fab up a kx 500 engine in a tecate? I have a motor laying around with carb and pipe ,all i would really need is a chasis, the electricals and prob weld up the frame a little different?
    Honda Atc 185-toy/snow beast!
    KX250f-race bike
    Klx110-pit bike
    May 2002
    Texas
    2,670
    I believe the KX500 motor will bolt right into a 1986/87 KXT Chassis. and then you have to clear a cross member in the upper frame for the spark plug.
    There's been a couple guys come across this board in the past that have done this and should be able to give you details.
    To put one in the 84/85 takes a major frame modification.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Jul 2003
    indiana
    892
    86-87 tecate's are realatively "simple" from what I have read. That is if you have the tools and skills to do it. Like a welder, torch, metal fab skills, etc. The 84-85 tecate is an entirely different story. You are going to have to cut the frame in the front and make it like the 86-87 frames fromt end.
    What year KX500 motors are best for the conversion? This sounds interesting. I have an 86 with a +3 swingarm now and a 285 kit and it does just fine. I would love to just shoehorn the 500 in and have unlimited potential.......hmmmmm
    Banshee Killer
    Feb 2005
    new york
    133
    Reply
    No frame modifications , the 500 bolts right in!!!
    Anaheim
    1,270
    i believe its like wat 250T is saying... drops right in... the frame should hold the power just fine... cause it already rattles like a jerk... i know that all kx500's can go in... i would personally go for a late 90's one as they had the most technology into them and they are reasonably affordable...
    Adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Sep 2005
    San Diego
    192
    I have seen a couple of these translants completed. The end results were quite stunning visually but the owners eventually changed back to the 250 engine because of serious vibration issues.
    One owner claimed that the frame had as much welding rod as tubing from welding up the recuring and constant cracks that developd anytime the trike was ridden.
    Good luck and ride safely.
    Dec 2003
    australia
    838
    There's one on ebay right now. Here's the address
    http://cgi.ebay.com/ebaymotors/1986-...24925914QQrdZ1
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    Mar 2004
    Austin
    58
    86/87 direct bolt in...Jeb is correct with the spark plug clearance issue, the cross member must be notched...
    SHUT up and ride..........
    Aug 2004
    Phoenix
    1,229
    Quote Originally Posted by CoeShow
    Same here. I have seen this also. The KX500 motor vibrates even MORE than the CR500. It snaps mounts, and vibrates things apart at an unbelievble rate.
    Newfoundland
    5,280
    Vibration aside you could do it and do it right by bracing, strengthening the frame and not just slapping the motor in and calling it done.
    Negatives aside it is one bad ass conversion.
    Jun 2004
    potsdam ny
    1,227
    3 razors, is it as bad on sand as it is on a hard surface?
    Aug 2004
    Phoenix
    1,229
    Hmmm I would say its about the same either on sand or hardpack. At lower rpm's its not so bad but when you really rev it out is when things start to not hold up on the tecate frame.
